New Contributor
Accepted Solution
TS3100 with 2 drives connect to Brocade B300 san switches
Hi,
I have Tape Libaray TS3100 with two FC Drives and two Brocade B300 san switches.
my question is about connectivity of Tape Libaray with SAN Switches.
i have been connected to One FC drive with SAN Switch-1 and Second Drive connect to SAN Swicth-2   am i correct or not ?
Regards,
Ayaz
Regular Contributor
Re: TS3100 with 2 drives connect to Brocade B300 san switches
Most tape libraries do not allow multipathing. Most tape libraries should be connected to a single fabric only.
Depending on the controlability of the tape library, there are "creative" ways that a TL could be connected to a dual fabric. But, that does require that each tape drive in a library be single fabric only. I've only seen this done once and that device would be hard pressed to be truely called a "library".
Super Contributor
From my experience, you may connect drive to both fabrics. After link failure you may switch to second path and reschedule backups.
Unfortunatelly i don't remember now if its driven by tape library or backup software.
Please mark this response as "Accept as Solution" if it answers your question.
Marian Bezeg
New Contributor
Thank you for your reply and Support . The issue has been resovled.
