Anonymous
Switches Firmware Upgrades
Hi team,
Im going to make same firmware upgrades, the machine, codes and jumps are:
Switches      Codes Source                                  Codes Target               Jumps
  200E                 5.3.0         IBM SAN16B-2           Max v6.2.2f         5.3.0> 6.0.0a -> 6.1.0a -> 6.2.2f
  4020                 5.3.1         4020                            Max v6.2.2f         5.3.1> 6.0.0a -> 6.1.0a -> 6.2.2f
  4020                 6.1.1d       4020                            Max v6.2.2f         6.1.1d -> 6.2.2f
I have configured my DCFM Enterprise with all codes and I see this information in DCFM and in WebTools:
DCFM.
You can see the type support are 34 (200e) and 37 (4020).
WEBTOOLS:
   webtools say type 34.0  (not 34 how dcfm say)
   webtools say type 37.1 (not 37 how dcfm say)
Is normal this little difference????,    why??
I dont want surprises in my upgrades......
Thanks.
Dany.
Frequent Contributor
Re: Switches Firmware Upgrades
The number after the dot is just the hardware revision. For example if there was a re-design of the board or a new manufacturing process... Usually it has no meaning for the user.
Anonymous
Hi Sebastian, morning.
I have tried to find some version with 37.1 but i dont find it.
I supousse that a version with support to switch type 37 (dcfm) is valid for switch type 37.1(webtools).
what do you think ?
dany
Valued Contributor
Hi,
Yes, type 37 and 37.1 are the same.
Take a look at that talks about switch types and models and I found it very useful.
Rgds,
Felipon
