Contributor
Switch hardware errors
Hello,
  I am getting the following errors on a DCX switch. Does anyone know what it means. Also is there any document that lists this type of errors and probable cause/fix.
Critical S5,C3: Above normal hardware errors were observed: fault1:0xd, fault2:0x64 thresh2:0xb0000064. Chassis 71 1 C3-1010
Thanks
Moeen
Frequent Contributor
Re: Switch hardware errors
From the FOS 7.1 Message Reference Guide:
C3-1010
Message                S<slot number>,C<chip index>: Above normal hardware errors were observed:
                             fault1:0x<fault1_cnt>, fault2:0x<fault2_cnt> thresh2:0x<threshold_used>.
Message Type        LOG
Severity                  CRITICAL
Probable Cause      Indicates that above-normal errors were observed in hardware that may or may not impact the data
                              traffic.
Recommended        When this error is observed persistently, power cycle the specified blade using the slotPowerOff
Action                      and slotPowerOn commands. If the problem persists, replace the blade.
Anonymous
is it a core blade in your case?
