Contributor
Accepted Solution
Switch did not come up after power outager
I have a customer who had a power outage
They have 2 switches of the tupe below
1 of the switches came back up after the power was restored
The other switch did not come up, customer had to puill the power cable
B 300
HP StorageWorks 8/24 SAN Switch
v7.3.1a
In the logs i cannot see anything logged fior the power outage, and no related events logged prior to the outage
Wi can only see that the switch is booting up adfter the cvable has been re-seated
2017/06/17-07:23:08:319078, [FW-5000], 2153/0, FID 128, INFO, SEBOXSANSW02, no license., alpa_agent.c, line: 819, comp:fwd, ltime:2017/06/17-07:23:08:318871
2017/06/19-07:42:56:723643, [CHS-5001], 2154/0, CHASSIS, INFO, Brocade300, Initialized the Chassis module., chassis_ent.c, line: 229, comp:insmod, ltime:2017/06/19-07:42:45:812767
2017/06/19-07:42:56:922065, [HAM-1004], 2155/781, CHASSIS, INFO, Brocade300, Processor rebooted - Reset., reboot.c, line: 112, comp:hamd, ltime:2017/06/19-07:42:52:191482
Any tip why the switch did not come back up ?
Broadcom Moderator
Re: Switch did not come up after power outager
Hi Thomas,
do you have any thing in a BNA server monitoring the switch or a configured syslog server which could indicate why the switch did not boot up after the power outage? What was the state of the switch LEDS, and Power Supplies LED?
Contributor
Hi Martin
No Syslog server is configured, no BNA either
I was informed that tyhere were no leds at all
Broadcom Moderator
Hi Thomas,
not much to go one.  Could be that the PS locked up, but really hard to determine root cause fo this. Not enough information, I am sorry to say.
Broadcom Moderator
Hi,
I agree with martin. It's really hard to tell what the power outage did to the power supplys in this case.
TL
