Contributor
Switch SAN FOS 8.1.2a compatibility with HPE 3PAR 7400 3.3.1 firmware
[ Edited ]
Hello,
I have 2 switch (IBM Type 133 = Brocade 6520) with FOS 8.1.2a and i need connect HPE 3PAR with firmware v.3.3.1, is compatibility with the SAN FOS?
thanks
Regards
Broadcom Moderator
Re: Switch SAN FOS 8.1.2a compatibility with HPE 3PAR 3.2.2 firmware
Hello,
Yes it is, see compatibility matrix attached, page 21 .
Contributor
[ Edited ]
Hello Thierry;
Thanks for your help, and sorry for the trouble but the storage is hpe 3par 7400 and now tell me that version is 3.3.1 and in the matrix appear 3par 8400, so it is compatibility even?
Regards
Broadcom Moderator
Hello,
Does the HPE is already installed on Brocade switches (prior 8.1.2a)?
Have you asked to your HP resseller?
Contributor
Hello Thierry;
- HPE is not installed yet, is installed in another SAN witch FOS 7.4.2
- I will read OEM of HPE 3PAR for more detail.
Thanks for your help.
Regards.
Broadcom Moderator
If it is already installed on 7.4.2 switch, it should be not a problem with 8.x switch.
