Contributor
Accepted Solution
Switch FC5022 : Interface disabled HTTP, I need to acces it with HTTP
IBM model :IBM Flex System FC5022 16Gb SAN Scalable Switches
or
Brocade model : Brocade 6547 Switch Module
  When I try to reach my switch with firefox with the adress http://x.x.x.x
I got this message :
Interface disabled This Interface (ADRESS IP OF MY PC) has been blocked by the administrator.
How can I disable the HTTPS? because with my BNA I cannot add it all my switches is http...
thank you
Valued Contributor
Re: Switch FC5022 : Interface disabled HTTP, I need to acces it with HTTP
Hi,
It looks to me as if the HTTP port 80 had been blocked within the active ipfilter policy. Please, take a look at the Active IP filter policy with command
ipfilter --show
And if access to port 80 is denied, change the policy. Try this first, and if does not work will try to figure out what else we could do.
rgds,
Felipon
Contributor
[ Edited ]
Yes is deny
Name: default_ipv4, Type: ipv4, State: active
Rule    Source IP                               Protocol   Dest Port   Action
1     any                                            tcp       22     permit
2     any                                            tcp       23       deny
3     any                                            tcp      897     permit
4     any                                            tcp      898     permit
5     any                                            tcp      111     permit
6     any                                            tcp       80       deny
7     any                                            tcp      443     permit
8     any                                            udp      161     permit
9     any                                            udp      111     permit
10    any                                            udp      123     permit
11    any                                            tcp      600 - 1023     permit
12    any                                            udp      600 - 1023     permit
Name: default_ipv6, Type: ipv6, State: active
1     any                                            tcp       22     permit
2     any                                            tcp       23       deny
6     any                                            tcp       80       deny
Valued Contributor
Hi,
then, you have to permit it. Please, try the following:
1.- Delete the rule that denies access to HTTP:
ipfilter --delrule default_ipv4 -rule 6
2.- Add a new rule that permits the HTTP access:
ipfilter --addrule default_ipv4 -rule 6 -sip any -dp 80 -proto tcp -act permit
Let us know how it goes.
Rgds,
Felipon
Contributor
SWITCH:root> ipfilter --delrule default_ipv4 -rule 6
Not allowed to change default policies
SWITCH:root> ipfilter --addrule default_ipv4 -rule 6 -sip any -dp 80 -proto tcp -act permit
Contributor
Hi Felipon,
thank you for your Help! I got help from a guru of Brocade and He found this solution :
ipfilter --clone ipv4 -from default_ipv4
ipfilter --delrule ipv4 -rule 6
ipfilter --addrule ipv4 -rule 6 -sip any -dp 80 -proto tcp -act permit
ipfilter --save ipv4
ipfilter --show
ipfilter --activate ipv4
