Anonymous
Switch 6520 and switch 5100 " E-Port segmented (incompatible)"
Hi,
Have bought new 6520 (FOS  v7.2.0a) that I need to connect to 5100, 5000 and 4020 (All FOS v6.2.2e).
Getting this....
  94  94   2a5e00   id    N4       Online      FC  E-Port  segmented,10:00:00:05:1e:56:05:8b (incompatible)
Acourdingly to page 20 following link, I expected it to work !
http://community.brocade.com/dtscp75322/attachments/dtscp75322/Certification/46/1/FOSv7.2.0a_releasenotes_v1.0.pdf
Ragards Lars
Regular Contributor
Re: Switch 6520 and switch 5100 " E-Port segmented (incompatible)"
Hi Lars,
did you disable QOS on the ISL-Ports?
Kind Regards
Ralf
Valued Contributor
hi,
check in the manual the requirements for two switchs to merge, and specially that the defzone is the same.
rgds,
Felipon
Regular Contributor
Use the "fabstatsshow" command as well as the "fabriclog" command to try and determine where the incompatibility is. Can be anywhere but most often an incorrect timer like R_A_TOV or E_D_TOV or even PID format or addres mode.
Lots of option but your post doesn't provide much info.
Kind regards,
Erwin van Londen
Brocade Distinguished Architect
http://www.erwinvanlonden.net The Fibre Channel blog
Q&A -> https://hackhands.com/elo/
