Anonymous
Switch 300 and ISL
Hi,
my questions about ISL trunk:
It can be created ISL trunk via a single cable?
Is this output fabricshow ISL trunk?
Switch ID Worldwide Name Enet IP Addr FC IP Addr Name
11: fffc0b 10:00:50:eb:1a:79:9c:3b 172.16.178.26 0.0.0.0 "NMSK0055"
12: fffc0c 10:00:00:05:1e:81:7b:16 0.0.0.0 0.0.0.0 >"NMSK0056"
What commands used to diagnose, the ISL work?
Thank you
Radek
Anonymous
Re: Switch 300 and ISL
Yes you can form an ISL with one port, but two is recommended for redundancy.
What is the output from switchshow, fabricshow, islshow?
You should be running the latest fos.
Anonymous
[ Edited ]
Hi,
Outputs are below and please inform us if the ISL okay.
Thank you
R.P
NMSK0056:admin> islshow
1: 15-> 15 10:00:50:eb:1a:79:9c:3b 11 NMSK0055 sp: 8.000G bw: 8.000G
NMSK0056:admin> fabricshow
11: fffc0b 10:00:50:eb:1a:79:9c:3b 0.0.0.0 0.0.0.0 "NMSK0055"
The Fabric has 2 switches
NMSK0056:admin> switchshow
switchName: NMSK0056
switchType: 71.2
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 12
switchId: fffc0c
switchWwn: 10:00:00:05:1e:81:7b:16
zoning: ON (Test_zone)
switchBeacon: OFF
Index Port Address Media Speed State Proto
0 0 0c0000 id N4 No_Light FC
1 1 0c0100 id N4 No_Light FC
2 2 0c0200 id N4 No_Light FC
3 3 0c0300 id N4 No_Light FC
4 4 0c0400 id N4 No_Light FC
5 5 0c0500 id N4 No_Light FC
6 6 0c0600 id N4 No_Light FC
7 7 0c0700 id N4 No_Light FC
8 8 0c0800 -- N8 No_Module FC
9 9 0c0900 -- N8 No_Module FC
10 10 0c0a00 -- N8 No_Module FC
11 11 0c0b00 -- N8 No_Module FC
12 12 0c0c00 -- N8 No_Module FC
13 13 0c0d00 -- N8 No_Module FC
14 14 0c0e00 -- N8 No_Module FC
15 15 0c0f00 id N8 Online FC E-Port 10:00:50:eb:1a:79:9c:
3b "NMSK0055" (downstream)
16 16 0c1000 -- N8 No_Module FC (No POD License) Disabled
17 17 0c1100 -- N8 No_Module FC (No POD License) Disabled
18 18 0c1200 -- N8 No_Module FC (No POD License) Disabled
19 19 0c1300 -- N8 No_Module FC (No POD License) Disabled
20 20 0c1400 -- N8 No_Module FC (No POD License) Disabled
21 21 0c1500 -- N8 No_Module FC (No POD License) Disabled
22 22 0c1600 -- N8 No_Module FC (No POD License) Disabled
23 23 0c1700 -- N8 No_Module FC (No POD License) Disabled
Both switches:
NMSK0056:admin> firmwareshow
Appl Primary/Secondary Versions
FOS v7.4.0a
v7.4.0a
Contributor
Hi Radek,
                  Single ISL link can not act as ISL Trunk.
Trunking Brief :
The trunking feature optimizes the use of bandwidth by allowing a group of links to merge into a
single logical link, called a trunk group. Traffic is distributed dynamically and in order over this trunk
group, achieving greater performance with fewer links. Within the trunk group, multiple physical
ports appear as a single port, thus simplifying management. Trunking also improves system
reliability by maintaining in-order delivery of data and avoiding I/O retries if one link within the trunk
group fails.
The following requirements apply to all types of trunking:
• The Trunking license must be installed on every switch that participates in trunking.
• All of the ports in a trunk group must belong to the same port group.
• All of the ports in a trunk group must be running at the same speed.
• All of the ports in a trunk group must be configured for the same distance.
• All of the ports in a trunk group must have the same encryption, compression, QoS, and FEC
settings.
• Trunk groups must be between Brocade switches (or Brocade adapters, in the case of F_Port
trunking). Brocade trunking is proprietary and not supported on M-EOS or third-party switches.
• There must be a direct connection between participating switches.
• Trunking cannot be done if ports are in ISL R_RDY mode. (You can disable this mode using the
portCfgIslMode command.)
• Trunking is supported only on FC ports. Virtual FC ports (VE_ or VEX_Ports) do not support
trunking.
