Anonymous
StorageWorks Power Pak 2/8-EL without any passwords -reset to default?
Hello,
I have 3 StorageWorks Power Pak 2/8-EL San Switch (VxWork, Fabric OS 3.1) without any passwords. The passwords fivranne, password with any combination of root, admin did not works. How can I reset the passwords to default?
Thanks a lot
Matthias
External Moderator
Re: StorageWorks Power Pak 2/8-EL without any passwords -reset to default?
Matthias,
we discussed at many time such password reset for VxWorks based switch, you may find answer here in the community.
password by default are:
for admin = password
for root = fibranne
fivranne with character "v" is not a default password by brocade this is incorrect.
TechHelp24
Anonymous
Thanks for your answer, fibranne also did not works I've already tried a few days before.
Valued Contributor
did you try factory:shantung?
Anonymous
facotry and shantung did not works
thanks for your answer
External Moderator
default pasword for account "factory" is "password"
the only way to reset the password ist to connect the switch to another switch trough ISL, both switch must be configure in same subnet.
when the ISL is established, you can try with the passwddefault utility to reset the password.
TechHelp24
