Anonymous
Storage system not communicating with the brocade San switch FCping fails. Why?
FCping shows the storage system is not communicating with the SAN switches its connected to.  How to resolve?
Valued Contributor
Re: Storage system not communicating with the brocade San switch FCping fails. Why?
Many storage systems just do not respond to fcping requests. BTW, what is your storage system vendor/model? Do you have any other problems that you are trying to resolve using fcping? Do you see a good name server entry for this storage port in the switch records?
Anonymous
Thanks Alexey,  I appreciate your response.  I think this is an anomally to the 3par Application, Peer Motion, i am working with.  The communication between 2 storage systems over FC. HP had me run that command and the results were. I thought i would check in the community anyway.
ams20-5100-001:admin> fcping 20:12:00:02:ac:00:07:cd 20:24:00:02:ac:00:56:37
fcping: Error destination wwn invalid   <-- RESULT
ams20-5100-001:admin> fcping 20:11:00:02:ac:00:07:cd 20:24:00:02:ac:00:56:37
The 1st wwn is from the older 3par and the 2nd the newer 3par I am migrating host to.
Valued Contributor
Well in this case your "new" 3par is really not present in the SAN...
Anonymous
I am seeing this error on 1 of my switches.
2015/06/08-18:28:48, [FW-1436], 3956, FID 128, WARNING, ams20-5100-001, Switch status change contributing factor Marginal ports: 8 marginal ports. (Port(s) 6(0x6),7(0x7),8(0x8),9(0x9),10(0xa),11(0xb),12(0xc),15(0xf))
