Anonymous
Silkworm 2800 firmware error
Hello All-
Anonymous
Re: Silkworm 2800 firmware error
Where did you get the firmware from? It is tied to switch WWN.
Anonymous
THANKS for the reply...J
Anonymous
I see, I am pretty sure that what you are seeing is a VxWorks error code not a FOS error code, I googled it and it appears that your ftp/rsh connection is being refused. Make sure that you use a password with ftp otherwise VxWorks assumes rsh
Anonymous
not to bad I_m_fdet... The problem was that I didn't have the rshd daemon running... and thats what I would expect from my windows box, but I connected to the switch with debian "sarge" (build 3.1, btw, I am debian master, you let me know if you have an 2.6.9.x linux question) and got the same error, anyway obtained a copy of rshd and stated its service, sure enough it worked fine... GOOD CALL i_m_fdetJ
Anonymous
INFC,Thank you.
