Anonymous
SilkWorm 3250 does not start
Hello,
I have one SilkWorm 3250, which does not start:
The system is coming up, please wait...
1) Start system.
2) Recover password.
3) Enter command shell.
Option? 1
PHY clear...
ENET Speed is 10 Mbs...
HALF duplex connection
Sending bootp request ...
bootp packets sent = 5
BOOTP failed.
Network boot failed.
1) Start system.
Option? 3
Password:
> printenv
ENET_MAC=00051E34BCC3
ENET_src=10.77.77.77
Is my flash bad? Can I somehow write a new image?
Thanks!
Rad
Super Contributor
Re: SilkWorm 3250 does not start
--->>> Is my flash bad?
seems to 99% as defective
--->>> Can I somehow write a new image?
No.
Anonymous
Hm, this is not very encouraging :-)
Here is more info for the environment, in case someone has any ideas:
> hinv
Boot PROM: Version 4.1.0, Checksum: 009df30c, Thu Mar 25 21:01:23 2004
Platform: SWBD27, Revision 3
Processor: CPU: 200 MHz PowerPC 405GP, Revision E
Primary data cache: 8 KB, 32 B lines
Primary instruction cache: 16 KB, 32 B lines
Flash memory: 16 MB x 16b @ 0xf0000000, Manufacturer ID 0x89, Device ID 0x18
Flash memory: 512 KB x 8b @ 0xfff80000, Manufacturer ID 0x1, Device ID 0x4f
PCI device: Bus 0, Slot 6, Function 0, Vendor 0x1657, Device 0x0001
Main memory: 128 MB (ECC) @ 0x00000000
        Processor Local Bus: 100 MHz
     On-chip Peripheral Bus: 50 MHz
    External Peripheral Bus: 25 MHz
    PCI Bus: 33 MHz (internal arbiter) (synchronous)
Thanks!
Anonymous
I'm understand that topic outdate, but answer to this question not right. This trouble can cause when system battery discharged and bootloader lost system variables. For starting system need enter valid system environment. This problem solved in topic http://community.brocade.com/thread/2345 , but it has another title and not relevant at search.
