Anonymous
Signal Loss
Does Brocade publish information on sigal loss budget? Data on the 2800 would be excellent.
Anonymous
Re: Signal Loss
hi -typical Rx sensitivity: -20
Anonymous
Re: Signal Loss
GF
External Moderator
Re: Signal Loss
GF,is the Extended Fabric License installed into a 5000 ?
TechHelp24
Anonymous
Re: Signal Loss
There is no Extended Fabric License as the line is only 10km. I have the ports set to LE for long distance settings.GF
External Moderator
Re: Signal Loss
GF,-&gt;&gt;&gt; Does the Extended Fabric license affect the power TX or RX? <BR><BR>Usually is not necessary by 10 KM Line, that is always a thing of the distance, I have first their ask understood it would have 80 km stretch.<BR><BR>-&gt;&gt;&gt; I thought it just affected the buffer credits.No, here no gives standard answer, but i will check what i can find and post later.
TechHelp24
Anonymous
Re: Signal Loss
