Occasional Contributor
Segmented zone conflict P0 and P1 on Brocade DCX 8510 8 SW1 and SW3
Good day to everyone
May i seek for you advice regarding encountered error on our DCX 8510-8. SW1 and SW3 P0 and P1 are segmented due to zoning conflict. When i try to run the islshow command it says incompatible. Please see logs below for further info.
switchshow | more
switchName:     DCX8510_SW1
switchType:     120.0
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   11
switchId:       fffc0b
switchWwn:      10:00:50:eb:1a:72:4e:00
zoning:         ON (DCX8510_SW1_SW3_CFG)
switchBeacon:   OFF
FC Router:      OFF
FC Router BB Fabric ID: 128
Address Mode:   0
HIF Mode:       ON
Index Slot Port Address Media  Speed        State    Proto
   0    1    0   0b0000   id    2G         Online      FC  LS E-Port  segmented,10:00:50:eb:1a:72:35:00 (zone conflict)
   1    1    1   0b0100   id    2G         Online      FC  LS E-Port  segmented,10:00:50:eb:1a:72:35:00 (Eport Isolated)
   2    1    2   0b0200   id    N8         Online      FC  F-Port  1 N Port + 1 NPIV public
   3    1    3   0b0300   id    N8         Online      FC  F-Port  1 N Port + 1 NPIV public
   4    1    4   0b0400   id    N4         Online      FC  F-Port  21:00:00:24:ff:2f:95:f4
   5    1    5   0b0500   id    N8         Online      FC  F-Port  10:00:00:90:fa:a3:65:58
   6    1    6   0b0600   id    N8         Online      FC  F-Port  1 N Port + 1 NPIV public
   7    1    7   0b0700   id    N16        No_Light    FC
   8    1    8   0b0800   id    N8         Online      FC  F-Port  21:00:00:24:ff:58:86:c1
   9    1    9   0b0900   id    N4         Online      FC  F-Port  10:00:00:00:c9:9c:67:fe
  10    1   10   0b0a00   id    N4         Online      FC  F-Port  21:00:00:1b:32:1c:41:0d
  11    1   11   0b0b00   id    N8         Online      FC  F-Port  1 N Port + 9 NPIV public
  12    1   12   0b0c00   id    N8         Online      FC  F-Port  50:06:01:69:08:60:3a:12
  13    1   13   0b0d00   id    N8         Online      FC  F-Port  10:00:00:90:fa:a3:2d:b8
  14    1   14   0b0e00   id    N16        No_Light    FC
  15    1   15   0b0f00   id    N16        Online      FC  F-Port  50:06:01:6b:47:e4:08:59
 128    1   16   0b8000   id    N8         Online      FC  F-Port  50:00:09:75:00:11:39:19
 129    1   17   0b8100   id    N16        No_Light    FC
 130    1   18   0b8200   id    N16        No_Light    FC
 131    1   19   0b8300   id    N16        Online      FC  F-Port  50:00:09:75:a8:04:50:44
 132    1   20   0b8400   id    N16        Online      FC  F-Port  1 N Port + 30 NPIV public
 133    1   21   0b8500   id    N16        Online      FC  F-Port  1 N Port + 20 NPIV public
 134    1   22   0b8600   id    N8         Online      FC  F-Port  1 N Port + 15 NPIV public
 135    1   23   0b8700   id    N8         Online      FC  F-Port  1 N Port + 15 NPIV public
 136    1   24   0b8800   id    N16        No_Light    FC
Type <CR> or <SPACE BAR> to continue, <q> to stop
fabstatsshow
Description                  Count   Port    Timestamp
Domain ID forcibly changed:       0
E_Port offline transitions:     342       1  Wed Oct 10 07:31:39 2018
Reconfigurations:               283       0  Wed Oct 10 07:33:31 2018
Segmentations due to:
                  Loopback:       0
           Incompatibility:       0
                   Overlap:       0
                    Zoning:      51 <     0  Wed Oct 10 07:33:31 2018
            E_Port Segment:       0
                 Licensing:       0
           Disabled E_Port:       0
               Platform DB:       0
       Sec Incompatibility:       0
             Sec Violation:       0
                 ECP Error:       0
             Duplicate WWN:       0
            Eport Isolated:      11
        AD header conflict:       0
            VF AD conflict:       0
  MSFR/RD H&T WWN conflict:       0
      ETIZ Incompatibility:       0
     ESC detected conflict:       0
       Encryption conflict:       0
      Compression conflict:       0
  Encryp/Comp bw availability:       0
          Defzone conflict:       0
islshow
  1:  0->  0 10:00:50:eb:1a:72:35:00 (incompatible)
  2:  1->  1 10:00:50:eb:1a:72:35:00 (incompatible)
portcfgshow
Ports of Slot 1         0   1   2   3     4   5   6   7     8   9  10  11    12  13  14  15
Octet Speed Combo       1   1   1   1     1   1   1   1     1   1   1   1     1   1   1   1
Speed                  2G  2G  AN  AN    AN  AN  AN  AN    AN  AN  AN  AN    AN  AN  AN  AN
AL_PA Offset 13        ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Trunk Port             ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON
Long Distance          LS  LS  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
VC Link Init           ON  ON  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Locked L_Port           -   -   -   -     -   -   -   -     -   -   -   -     -   -   -   -
Locked G_Port          ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON
Disabled E_Port        ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Locked E_Port          ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
ISL R_RDY Mode         ..  ON  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
RSCN Suppressed        ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Persistent Disable     ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
LOS TOV mode            0   0   0   0     0   0   0   0     0   0   0   0     0   0   0   0
NPIV capability        ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON
NPIV PP Limit          126 126 126 126   126 126 126 126   126 126 126 126   126 126 126 126
NPIV FLOGI Logout      ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
QOS Port               ..  ..  AE  AE    AE  AE  AE  AE    AE  AE  AE  AE    AE  AE  AE  AE
EX Port                ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Mirror Port            ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Rate Limit             ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Credit Recovery        ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON
Fport Buffers          ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Eport Credits          ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Port Auto Disable      ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
CSCTL mode             ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
D-Port mode            ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
D-Port over DWDM       ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Compression            ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Encryption             ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
FEC                    ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON    ON  ON  ON  ON
FEC via TTS            ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Fault Delay             0   0   0   0     0   0   0   0     0   0   0   0     0   0   0   0
SIM Port               ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
8G Non-DFE             ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
TDZ mode               ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
SW3
switchshow        :
switchName:    DCX8510_SW3
switchType:    121.3
switchState:    Online
switchMode:    Native
switchDomain:    13
switchId:    fffc0d
switchWwn:    10:00:50:eb:1a:72:35:00
switchBeacon:    OFF
FC Router:    OFF
Address Mode:    0
HIF Mode:    ON
   0    1    0   0d0000   id    2G       Online      FC  LS E-Port  segmented,10:00:50:eb:1a:72:4e:00 (zone conflict)
   1    1    1   0d0100   id    2G       Online      FC  LS E-Port  segmented,10:00:50:eb:1a:72:4e:00 (zone conflict)
   2    1    2   0d0200   id    N16       Online      FC  F-Port  50:01:73:80:69:ea:01:10
   3    1    3   0d0300   id    N8       Online      FC  F-Port  10:00:00:90:fa:13:78:f3
   4    1    4   0d0400   id    N4       Online      FC  F-Port  50:05:07:63:04:10:95:b2
   5    1    5   0d0500   id    N8       Online      FC  F-Port  50:05:07:68:0c:14:05:0d
   6    1    6   0d0600   id    N8       Online      FC  F-Port  10:00:00:90:fa:13:79:03
   7    1    7   0d0700   id    N8       Online      FC  F-Port  50:00:09:75:00:11:3d:14
   8    1    8   0d0800   id    N4       Online      FC  F-Port  10:00:00:00:c9:da:99:68
   9    1    9   0d0900   id    N8       Online      FC  F-Port  10:00:00:90:fa:50:ea:b0
  10    1   10   0d0a00   id    N16       Online      FC  F-Port  50:01:73:80:69:ea:01:11
  11    1   11   0d0b00   id    N8       Online      FC  F-Port  50:00:09:75:00:11:3d:1c
  12    1   12   0d0c00   id    N8       Online      FC  F-Port  50:05:07:63:04:08:15:b2
  13    1   13   0d0d00   id    N8       Online      FC  F-Port  50:05:07:63:04:18:15:b2
  14    1   14   0d0e00   id    N8       Online      FC  F-Port  50:05:07:60:48:40:b2:5f
  15    1   15   0d0f00   id    N8       Online      FC  F-Port  50:00:09:75:00:11:3d:20
  16    1   16   0d1000   id    N8       Online      FC  F-Port  50:06:01:69:08:60:45:1c
  17    1   17   0d1100   id    N16       Online      FC  F-Port  50:01:73:80:69:ea:01:13
  18    1   18   0d1200   id    N16       No_Light    FC
  19    1   19   0d1300   id    N8       Online      FC  F-Port  50:00:09:75:00:11:3d:60
  20    1   20   0d1400   id    N16       No_Light    FC
  21    1   21   0d1500   id    N8       Online      FC  F-Port  10:00:00:90:fa:13:ad:d1
  22    1   22   0d1600   id    N8       Online      FC  F-Port  1 N Port + 6 NPIV public
  23    1   23   0d1700   id    N8       Online      FC  F-Port  50:05:07:60:48:40:b1:a7
  24    1   24   0d1800   id    N8       Online      FC  F-Port  50:05:07:63:04:00:15:b2
  25    1   25   0d1900   id    N8       Online      FC  F-Port  1 N Port + 34 NPIV public
  26    1   26   0d1a00   id    N16       Online      FC  F-Port  1 N Port + 7 NPIV public
  27    1   27   0d1b00   id    N8       Online      FC  F-Port  21:00:00:24:ff:7f:81:e2
  28    1   28   0d1c00   id    N16       No_Light    FC
  29    1   29   0d1d00   id    N8       Online      FC  F-Port  21:00:00:24:ff:7f:81:e6
  30    1   30   0d1e00   id    N8       Online      FC  F-Port  50:06:01:61:47:20:5f:1c
  31    1   31   0d1f00   id    N16       No_Light    FC
  32    1   32   0d2000   id    N8       Online      FC  F-Port  21:00:00:24:ff:7f:84:a6
  33    1   33   0d2100   id    N8       Online      FC  F-Port  50:00:09:75:00:11:3d:5c
  34    1   34   0d2200   id    N8       Online      FC  F-Port  21:00:00:24:ff:91:92:18
  35    1   35   0d2300   id    N16       No_Light    FC
  36    1   36   0d2400   id    N16       No_Light    FC
  37    1   37   0d2500   id    N16       Online      FC  F-Port  50:06:01:6b:47:e4:09:0e
  38    1   38   0d2600   id    N8       Online      FC  F-Port  1 N Port + 1 NPIV public
  39    1   39   0d2700   id    N2       Online      FC  F-Port  21:00:00:e0:8b:19:fa:25
  40    1   40   0d2800   id    N16       Online      FC  F-Port  50:06:01:62:47:e4:09:0e
  41    1   41   0d2900   id    N8       Online      FC  F-Port  10:00:00:00:c9:d5:53:12
  42    1   42   0d2a00   id    N8       Online      FC  F-Port  21:00:00:24:ff:7f:82:4e
  43    1   43   0d2b00   id    N8       Online      FC  F-Port  10:00:00:90:fa:91:5e:1e
  44    1   44   0d2c00   id    N4       Online      FC  F-Port  21:00:00:e0:8b:8a:fd:d8
  45    1   45   0d2d00   id    N8       Online      FC  F-Port  21:00:00:24:ff:7f:81:e4
  46    1   46   0d2e00   id    N4       Online      FC  F-Port  21:00:00:24:ff:2b:d3:7a
  47    1   47   0d2f00   id    N8       Online      FC  F-Port  50:05:07:60:48:40:a3:ba
fabstatsshow        :
E_Port offline transitions:     342       1  Wed Oct 10 07:41:05 2018
Reconfigurations:               288       1  Wed Oct 10 07:41:53 2018
                  Loopback:       0
           Incompatibility:       0
                   Overlap:       0
                    Zoning:      63 <     1  Wed Oct 10 07:41:53 2018
            E_Port Segment:       0
                 Licensing:       0
           Disabled E_Port:       0
               Platform DB:       0
             Sec Violation:       0
                 ECP Error:       0
             Duplicate WWN:       0
            Eport Isolated:       0
            VF AD conflict:       0
          Defzone conflict:       0
islshow        :
  1:  0->  0 10:00:50:eb:1a:72:4e:00 (incompatible)
  2:  1->  1 10:00:50:eb:1a:72:4e:00 (incompatible)
portcfgshow        :
ISL R_RDY Mode         ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..    ..  ..  ..  ..
Appreciate any advice / feedback :) THANKS!
Regular Contributor
Re: Segmented zone conflict P0 and P1 on Brocade DCX 8510 8 SW1 and SW3
You have one port as ISL R_RDY Mode.
Are you running WDM gear? If so, does that WDM gear require ISL R_RDY Mode? (Search the forum for ISL R_RDY Mode for a most excellent write up it's limitations.)
