New Contributor
San Brocade 5100 won't Booting
Hello All,
Please help me.. I have some problem with my San Switch Brocade 5100 won't booting.
I have restart but still problem..
The problem occur suddenly, and cannot ping (icmp) that device, and I console this device i found log, like below:
WARNING: Boot Monitor checksum failure, primary partition.
WARNING: Boot Monitor checksum failure, mirror partition.
ERROR: Boot Monitor Selector failed to find a bootable image!ÿ The system is coming up, please wait...
Could you give me solution.. may be step bu step i must do it.
Thank you for your kind cooperation..
Best Regards,
Elzantes
New Contributor
Re: San Brocade 5100 won't Booting
Please help me.. maybe anybody can give me some advice..
External Moderator
@elzantes
show as a Hardware Failure or the CF Inside is damaged.
I would suggest to open a TAC with Brocade or they OEM Provider or Vendor
TechHelp24
New Contributor
Dear Antonio,
Ouhh.. there are hardware failure.. so the device can back to normal again or not?
Ookay, I'ill contact the Vendor.
Thank you for you advice
External Moderator
if the switch have a hardware failure, as saied you have to open a TAC and in some circumstance the Switch must be replaced,
Premise you have a Active Maintenance Contract !!!
good luck
TechHelp24
