Occasional Contributor
Accepted Solution
SNMPv1 and logical switches
Hi guys,
we use Brocade 6510 switches with three logical switches on every single switch. I would like to monitor the switches with Observium or Stor2rrd. I'm planing to use SNMPv1 to get some information out of the switches. My current problem is: I only get the information regading the base switch ports and the other hardware components like CPU/RAM/... NOT for the ports which are assigned to the other logical switches.
Is there a trick how to get information regarding the other ports? (ports outside of the base switch)
Thanks in advance!
Broadcom Moderator
Re: SNMPv1 and logical switches
Hi.
to get data from other logical switches, you must use snmp v3 - the context parameter under snmpv3 is used to selected the logical switch (based on FID) as in  "VF:128" or "VF:64"
[ Edited ]
Hi Martin,
thank you for the reply.
I disabled v1 and configrured v3. I configured a snmp read-only user and assigned that user to the home logical switch 10. Now Observium get the information for all ports from ls 10, but not from the base ls (128) or the other one (20).
If I switch the user to base ls 128, than I only can see the switch ports from ls 128.
Is there something else I can configure on the switches? I would like to get ALL ports not only the home ls.
Btw. I also did a test with Store2rrd and I get the same result. I get only the switchports from the assigned ls of the user. :-/
#UPDATE:
I think I understood your second part now :-)
I need to change the query, right? (snmpwalk)
Broadcom Moderator
Hi,
the snmp user need to have access (userconfig) to the FID 20, and FID 128. So you need add LF 20 and 128, or easer to all FIDs to the snmp user.
Hi,
the user has access to all (1-128) logical switches.
This is how I added the user:
userconfig --add snmp_ro_3 -r user -l 1-128 -h 10 -c user -d "User for Observium"
Broadcom Moderator
Hi,
some notes from the BNA 14.0.x manual - try use admin instead of user (you use Read Only, so it less of than issue)
To collect performance data on a Virtual Fabrics-enabled device, use the userconfig --show
command to make sure the Fabric OS user has access to all the Virtual Fabrics. Make sure that
the SNMPv3 user name is the same as the Fabric OS user name. Otherwise, the data is not
collected for virtual switches with a non-default Virtual Fabric ID. By default, the admin user
has access to all Virtual Fabrics.
Example of Fabric OS user verification
sw1:FID128:admin> userconfig --show
Account name: admin
Description: Administrator
Enabled: Yes
Password Last Change Date: Unknown
Password Expiration Date: Not Applicable
Locked: No
Home LF Role: admin
Role-LF List: admin: 1-128
Chassis Role: admin
Home LF: 128
[ Edited ]
Thank you for your reply!
I already try this. Currently the user is -r admin and -c admin. But I still only see the ports from the home ls
Here is a userconfig --show snmp_ro_3
Account name: snmp_ro_3
Description: User for Observium
Enabled: Yes
Password Last Change Date: Tue Sep 12 2017 (UTC)
Password Expiration Date: Not Applicable (UTC)
Locked: No
Home LF Role: admin
Chassis Role: admin
Home LF: 10
Broadcom Moderator
Hi,
I looked briefly looked at Observium but I could not find any support of SNMP v3 context (VF:<FID>) currently, it look like. If it is true, then you will only have statistics from the home FID/VF for the snmp user. I have downloaded (or tried) to take a look context is supported or not.
Thanks for your support Martin!
I did the following workaround for now:
- Created three snmp_ro user and assigned each user in a different home FID
- Created an Observium host for every logical swtich --> switch_ls_128, switch_ls_10, switch_ls_20
Now I can see all ports, but scattered over three objects. Well, that isn't the best result but finally I can see every port. :-/
New Member
Hi,
there is detailed description in STOR2RRD docu how to activate it, just follow it:
http://www.stor2rrd.com/install.htm#SAN
You have to use SNMP v3 with proper security user
Activate SNMP v3 mode in etc/san-list.cfg
Configure security user on the switch (under admin account):
userconfig --add snmpuser1 -r user -l 1,128
userconfig --change snmpuser1 -r user -l 1,128 -h 128 -e no
Parameter -l says which virtual fabrics can be monitored by this user.
Example above allows virtual fabrics 1 and 128 for user snmpuser1.
test access, you should see ports configured for your specific VF (Virtual Fabric).
$ snmpwalk -v 3 -u snmpuser1 -n VF:<your_virtual_fabric_ID> <Switch_IP> 1.3.6.1.2.1.1.5
  SNMPv2-MIB::sysName.0 = STRING: SAN_switch_name
If you get one of below errors then user is not configured properly:
Error in packet.
Reason: noAccess
snmpwalk: Unknown user name
