Occasional Contributor
SNMP credentials for BNA and Login issues
Hi all,
I have the same in several Access gateway.
I created an account for BNA bt I cannot login into the swich witch it directly :
ssh admbna@SW1
admbna@SW1's password:
Connection to SW1closed.
The login work only after connecting to the switch with the root acount , but there is this message " No directory ! Logging in with home = "/".
SW1:root> login
SW1 login: admbna
Password:
No directory !
SW1 :admbna>
I don't know how to fix it and it occur on sveeral Access Gateway (Fabric OS:  v6.2.2b).
Thank you in advance for your help.
Valued Contributor
Re: SNMP credentials for BNA and Login issues
 how did you create that user account?
could you please post the output of:  userconfig --show
rgds
