New Contributor
SHA-512 and 4096-bit keys
Does anyone now when FOS will begin to support 4096-bit key lengths and SHA-512 in the FCAP and LDAP CA certificates?  My local CA admins keep wanting to require those levels.
Broadcom Moderator
Re: SHA-512 and 4096-bit keys
[ Edited ]
Hi,
there are improvents from FOS 8.0.1 as seen from the extract from the seccertutil
http://www.brocade.com/content/html/en/command-reference-guide/fos-80x-commandref/wwhelp/wwhimpl/js/html/wwhelp.htm#href=commands_a_z.secCertUtil.html
where we see
seccertutil generate [-fcap] [-keysize 1024 | 2048] [-hash sha1 | sha256] [-nowarn]
seccertutil generate [-commoncert] [-keysize 1024 | 2048] [-hash sha1 | sha256] [-nowarn]
seccertutil generate -https [-keysize 1024 | 2048 | 4096 | 8192] [-type rsa | dsa] [-hash sha1 | sha256 | sha512] [-years value] [-nowarn]
