Contributor
SAN switch -- not working
One of our 32-port switch is not working
from the past 6 months, today i just have looked at it. When i power on
the switch, on the console, i can see that it continuously doing some
diagnostics testing and continuously dumping cores.
I am not understand whether problem is with hardware or some problem with Fabric OS.
I have attached the console log.
Thank you.
External Moderator
Re: SAN switch -- not working
Hi,
is appear a FOS Problem.
Can yuo Login in the switch trugh Telnet or Console ?
If yes, what is th exact current FOS Release ? what say "firmwareshow"
call the command "savecore -l" and collect the output.
Post all this here.
TechHelp24
TechHelp24
Contributor
swd77:root> firmwareshow
Primary partition: v4.2.0b
Secondary Partition: v4.2.0b
swd77:root>
" savecore -l" commandgives very big output.
/core_files/fdet.10_17_2007-09:19:23/core.ptdata_s0p14
/core_files/fdet.10_17_2007-09:19:23/core.ptdata_s0p15
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p0
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p1
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p2
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p3
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p4
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p5
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p6
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p7
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p8
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p9
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p10
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p11
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p12
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p13
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p14
/core_files/fdet.10_17_2007-09:19:23/core.ptroute_s0p15
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p0
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p1
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p2
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p3
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p4
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p5
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p6
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p7
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p8
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p9
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p10
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p11
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p12
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p13
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p14
/core_files/fdet.10_17_2007-09:19:23/core.ptstats_s0p15
/core_files/fdet.10_17_2007-09:19:23/core.ptlog
/core_files/fdet.10_17_2007-09:19:23/core.errdump
/core_files/fdet.10_17_2007-09:19:23/core.dmesg
/core_files/fdet.10_17_2007-09:19:23/core.cmbuf_s0q0b0x58
/core_files/fdet.10_17_2007-09:19:23/core.cmbuf_s0q1b0x58
/core_files/fdet.10_17_2007-09:19:23/core.cmbuf_s0q2b0x58
/core_files/fdet.10_17_2007-09:19:23/core.cmbuf_s0q3b0x58
/core_files/panic/core.pd1141366176
/core_files/panic/misc.pd1141366176
find: /mnt/core_files/*/: No such file or directory
Thank you,
External Moderator
shushi,
i note you are logged as root, can you login as admin ?
1) connect and login as admin whit Hyper Terminal or equivalet Telnet Software.
2) select Capture text, and save the file
collect in this file all follow output
"switchtshow"
"licenseshow"
"firmwareshow" ( can you see both partition ? )
"savecore" ( dont remove any dump a this time )
"savecore -l"
save the file.
log as root an same procedure and save the output of
/df
or
/bin/df
save the file and upload both text file here.
TechHelp24
Contributor
I have attached those two files. Thank you.
External Moderator
Shushi,
Ok, the /df and both Prim. and Sec.Partition work fine
Log as admin Remove the core file, with the command "savecore" select 5 marked file and than 3 remove marked file.
here the link to download the FabOS.
BTW. i note from output of switchshow, this is not a 3900 this switch is Brocade 3850 ( Switch Type 26 ) Value Line.
Download from here the FabOS, you must !!! Upgrade with intermediate Release.
First from current 4.2.x to 4.4.x
from 4.4.x to 5.0.x from 5.0.x to 5.1.x from 5.1.x to 5.2.x from 5.2.x to 5.3.x
TechHelp24
TechHelp24
Contributor
Thank you very much for this hint.
From the URL which you have mentioned, i am not able to find 5.0.X and 5.1.X releases.
But i can see 4.4.X, 5.2.X and 5.3.X relases,
Please can you give me the right URL/correct flow-of-update ?
Thank you once again.
External Moderator
here is 5.0.x is the same FabOS Package.
You can Upgrade from 5.0 to 5.2 w/o intermediate release, see attached Release Notes.
Firmware Upgrades and Downgrades
Brocade does not support upgrading from more than two previous releases. For example, upgrading
from Fabric OS v5.0.x to v5.2.x is supported, but upgrading from Fabric OS v4.4.0 or a previous release
directly to v5.2.x is not.
Upgrading a switch from Fabric OS v4.4.0 or a previous release to v5.2.0 requires a two-step process:
first upgrade to v5.0.x or v5.1.x and then upgrade to v5.2.0.
TechHelp24
TechHelp24
Contributor
As the first step, i have updated firmware to v4.4.X.
No core files now. ("savecore -l" command gives "no core files found".
But if i try to enable a port, it says
swd77:root> portenable 11
portEnable failed. Possible reasons are:
Switch may be disabled, POD license is NOT installed, slot is off or port is persistently disabled.
Also, since FICON Management server mode (fmsmode) is enabled, the switch could be busy with another command. If so, please try again later.
swd77:root>
But the switch is enaled, GBICS are installed in all ports.
Why i am getiing this error ?
External Moderator
shashi,
what say the "firmwareshow"
do you have upgrade trugh the webtools or per comannd "firmwaredownload" ?
collect in a file the output of "errorshow" and upload here.
TechHelp24
