New Contributor
SAN SN6500B switch port doesn't show NPIV
Dear all,
We have SN6500B 96 port where we have connected a VM with NPIv.
Now that the switch port do support NPIV and has the NPIV capability ON, still the connection is showing just a single WWPN number rather than something like below:-
id    N8      Online      FC  F-Port  1 N Port + 2 NPIV public
We would want it to show the NPIV public connected to the port.
Where exactly are we missing anything.
Broadcom Moderator
Re: SAN SN6500B switch port doesn't show NPIV
Hello,
Since the enable of NPIV on the port, have you disable/enable the port?
Note that:
If the NPIV feature is disabled, the port is toggled if NPIV devices are logged in from that F_Port (a true NPIV port). Otherwise, the firmware considers that port as an F_Port even though the NPIV feature was enabled.
Broadcom Moderator
Hi,
the line below
means that 2 NPIV devices are connected to port.
To display the WWPN, you would need to use the portloginshow CLI, e.g. one example
portloginshow 162
Type  PID     World Wide Name        credit df_sz cos
  fd  3ed76c c0:50:76:07:c6:9e:00:08    40  2048   c  scr=0x3
  fd  3ed741 c0:50:76:07:c6:9e:00:00    40  2048   c  scr=0x3
  fe  3ed740 10:00:00:90:fb:50:89:60    40  2048   c  scr=0x3
  ff  3ed76c  c0:50:76:07:c6:9e:00:08    12  2048   c  d_id=FFFFFC
  ff  3ed741  c0:50:76:07:c6:9e:00:00    12  2048   c  d_id=FFFFFC
  ff  3ed740  10:00:00:90:fb:50:89:60    12  2048   c  d_id=FFFFFC
