Anonymous
Reset to default setting Brocade 300
Hi sorry for my englisch . I am beginner with FC . I have Brocade 300 without knowing admin password .How I change password for this device ? I try default root and password. Not work . With serial cable I connect to FC , why I set password ?
thanx
External Moderator
Re: Reset to default setting Brocade 300
default credentials are:
admin = password
if both password was changed, you must reset it with "password recovery procedure"
search here in the community, you may find a lot of thread how to.
Message was edited by: Antonio Bongiorno
TechHelp24
Anonymous
And if I want reset device to factory setting ? Must I reset password ? I try boot with parameter -s but not affect , the boot is normal and cannot I use  /etc ...
Valued Contributor
Hi,
Once you have been able to access CLI, try configdefault -all. That should reset the config to factory defaults. Unfortunately, this command resets nonpersistent configuration parameters only. The following parameters are
not affected by this command:
• Ethernet MAC address, IP address, subnet mask, and boot ROM parameters
• IP gateway address
• License keys
• OEM customization
• Product ID and Vendor ID
• SNMP configuration
• iSCSI configuration
• System name
• Chassis name
• World wide name
• Zoning configuration (includes aliases, zones, and configurations)
• Security parameters and policies
• User account passwords (includes all user configuration and all built-in accounts)
• Switch PID format
• Ethernet Link Mode
Check FOS Command Reference Manual to change SNMP, Names, IP Addresses to defaults...
Rgds
External Moderator
--->>> I have Brocade 300 without knowing admin password .
--->>> And if I want reset device to factory setting ? Must I reset password ?
before you can do anything/command, must login to the switch.
and the First Step is to reset the password with pwd recovery procedure.
TechHelp24
