Member
Accepted Solution
Regenerate licences for unsupported switch
Hi,
I have 2 old "HP 8/24c SAN Switch Pwr Pk+ BladeSystem c-Class", which apparently are Brocade 300 series switches. I wanted to reuse them in dev/test setup, but as I found out no licences are installed on the switches:
SANR3:root> licenseshow
No licenses installed.
HP model and serial number suggests that theese should come with good set of licences.
It is a dev/test setup and we don't have budget for getting those under support.
Is there a way to regenerate the licences that should have come with teh switch when purchased?
Regards,
Bartek
External Moderator
Re: Regenerate licences for unsupported switch
@barteks
if the switches are under maintenance, you have to open a TAC trough HP with a prof of purchase in order to get the license key.
TechHelp24
