Anonymous
Recommended FOS and EOS for ISL between DCX and M6140
We have a DCX that is ISL'ed to two McData 6140 switches. We have been told to upgrade the firmware on the DCX to 6.2.1.a. Is there a recommended version for the McData that should be upgraded as well? The McData's are currently at 9.7.2.1. Does anyone have any technical information why or why not the upgrades should be done at the same time.
Nancy
External Moderator
Re: Recommended FOS and EOS for ISL between DCX and M6140
Nancy,
see in the Brocade Fabric OS Release Notes for compatibility beetwen the best supported Release for FabricOS and M-EOS.
TechHelp24
External Moderator
--->>> Does anyone have any technical information why or why not the upgrades should be done at the same time.
see attached Release note please FabOS and EOS
TechHelp24
External Moderator
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thanks!
TechHelp24
