New Contributor
Re: Brocade 2005-R18 won't initialize
I have a problem with 2005-R18 machine, it won't initialize and all the fc ports has amber lights on.
This is the error we encounter.
2016/10/23-22:43:06, [BL-1027], 160671, CHASSIS, CRITICAL, IBM_2005_R18,
Blade in slot 0 faulted, boot failed; status 0x0 0x30 0x30. - Error
External Moderator
@TengV
I assume the switch is not longer under maintenance contract, I'm right ?
The 2005-R18 = 7500 technically is based on Brocade FR4-18i Blade with wich differed a few less Backplane Connectors.
The 7500 have inside a embedded CP with integrated Backplane, where the blade board is connected.
Back to you error message, did you get / follow other error excepted the BL-1027 ?
TechHelp24
New Contributor
It's under maintenance. Here's the exact error we encounter.
2016/10/31-06:31:06, [BL-1027], 163019 CHASSIS, CRITICAL, IBM_2005_R18, Blade in slot 0 faulted, boot failed; status 0x0 0x30 0x30.
2016/10/31-06:31:06, [BL-1034], 163020, CHASSIS, ERROR, IBM _2005_R18, Switch set to faulty, rc=20015.
Let me also give you version.
Kernel: 2.6.14.2
Fabric OS: v6.4.3h
Made on: Wed Sep 30 20:53:24: 2015
Flash: Thu Oct 27 08:38:29 2016
BootProm:  4.6.6
External Moderator
Hello,
->It's under maintenance.
That fine.
BL-1034 from err message manuals say not action is required, but from you output the switch show as Faulty.
at this point I would suggest to Open a TAC with Brocade or you OEM supplier.
TechHelp24
New Contributor
Hello,
Do you have idea how can I boot on alternate partition, can you guide me, I want to break to boot loader.
External Moderator
@TengV
as per my opinion, since the Switch ist continued under Maintenance Contract, you should provide tyo Open a TAC.
TechHelp24
Regular Contributor
Hi,
you can try slotpoweroff and slotpoweron.
Kind Regards
Ralf
New Member
Hey ..
I kknow it's an old topic, but have you succesfully break into FR4-18i boot ? or boot into alternate partition.
Thanks in advance
Broadcom Moderator
Hi,
do we speak about the 7500 or the blade Fr4-18i in a chassis?
