New Contributor
Accepted Solution
Re: Brocade 2005_B16 need to upgrade to latest firmware
Hello,
I have a Brocade 2005_B16 with Fabric OS v5.3.0, I need to upgrade it to latest firmware.
Can I have the step by step firmware needed and where to download the old firmware. Thanks
Broadcom Moderator
Hello,
Brocade 200E can support FOS versions until 6.2x.
Brocade 200E switch is EOL and EOS (End of Life and End of Service), all supported FOS versions for this unit are also EOA (End of Availability).
Broadcom Moderator
Your maintenance provider or OEM should be able to provide the old firmwares.
