Anonymous
REQ: documentation for 'multipathing' on single switch.
Hi,
External Moderator
Re: REQ: documentation for 'multipathing' on single switch.
what is intended with 'multipathing' ?'multipathing' is not Directly Native support by the switch, you can use Multipath with Additional Software, example PowerPath by EMC.
TechHelp24
Anonymous
The same node has 2 fibres connecting to each switch. I need to see every path.I've done the stmsboots (MPXIO) but it's mpathadm list lu still only shows half the connections (2) available.
External Moderator
hi assume this "stmsboots and mpathadm" are executable command in Solaris, is Correct ?Please execute the command "nsshow" ( by Connect all HBA/Port to the switches ) and post the result here.
TechHelp24
Anonymous
I have since resolved this issue: which was an issue in our StorageTek arrays - which only likes one 'primary path per controller'.
We have since then quad-attached the host to the array and got increased throughput that way.
