Turn on suggestions
Showing results for
10-03-2014 05:29 AM
Hi
I have a Brocade 20 port 8Gb SAN Switch Module for IBM BladeCenter with firmware version v6.3. I tried to build a fabric with other 2 IBM/BROCADE b24. After put this on fabric my Principal switch gives a error and reboots
Qua Out 01 2014 17:25:16 GMT+00:00 Warning Software 'verify' error detected. Switch 27 1 RAS-1004 SW_SAN_1_Princ
Qua Out 01 2014 17:25:16 GMT+00:00 Information First failure data capture (FFDC) event occurred. Chassis 28 1 RAS-1001 SW_SAN_1_Princ
Qua Out 01 2014 17:25:17 GMT+00:00 Warning Detected termination of process zoned0:1061 Chassis 29 1 KSWD-1002 SW_SAN_1_Princ
Qua Out 01 2014 17:25:17 GMT+00:00 Critical Non restartable component (zone (pid=1061)) died. Chassis 30 1 HAM-1014 SW_SAN_1_Princ
Qua Out 01 2014 17:25:19 GMT+00:00 Information The last fabric change happened at: Wed Oct 1 17:25:14 2014 Switch 31 1 SNMP-1007 SW_SAN_1_Princ
Qua Out 01 2014 17:25:27 GMT+00:00 Information First failure data capture (FFDC) event occurred. Chassis 32 1 RAS-1001 SW_SAN_1_Princ
Qua Out 01 2014 17:27:55 GMT+00:00 Information Processor rebooted - Software Fault:Kernel Panic Chassis 33 1 HAM-1004 SW_SAN_1_Princ
Qua Out 01 2014 17:28:01 GMT+00:00 Warning Trace dump available ! (reason: PANIC) Chassis 34 1 TRCE-1001 SW_SAN_1_Princ
Qua Out 01 2014 17:28:01 GMT+00:00 Warning Trace dump was not transferred because trace auto-FTP disabled. Chassis 35 1 TRCE-1004 SW_SAN_1_Princ
After this error, i`m update firmware to v6.4.0c the same version of the other one in the fabric.
The upgrade is gone fine, but after the upgrade i,m do a reset to default of FC on the blade console, then i have errors of RBAC permission deined on any command that i run on ssh with root account. I can`t log in on web interface .
Can some one help me.
