Contributor
Questions on DCX -- 10-bit fcid
Friends,
we have DCX fabric switches in our env. I have always tried to understand the fcid addressing of it. But I always gets confused with the additional 2 bit addressing which comes to 10-bit addressing. I am not getting the right concept about the port numbering and fc id addressing. Please help me to understand it.
Valued Contributor
Re: Questions on DCX -- 10-bit fcid
Hi,
Please, take a look at Brocade FOS admin guide where 10-bit addressing mode is explained. In short, with 8-bit addressing only 256 ports can be addressed, since  a DCX supports more than 256 ports, it needs to use 2 additional bits to address all the ports.
Rgds,
Felipe
Contributor
Hi Kishore,
               you can find the detailed explanation on BCFA Nutshull study guide and also from FC101 Fiber channel concepts guide.
The ability to address 384 ports in a single switch required a change to the standard 24-bit addressing
scheme. The second byte of a PID is referred to as the Area ID; with 8 bits, the Area ID can address ports 0–
255. Brocade now uses the third byte of the PID to address ports 256-383. The third byte of a PID is referred
to as the node address and was used to identify the loop address (ALPA) for a loop device. Since an FC8-48
port does not support loop devices the node address can be used to identify ports in the 256-383 range. This
requires the Area ID to be shared (used twice).
- Regards,
  Felix.
