New Contributor
Public key export problem from Brocade 5480 switch
Hi,
I am having difficulties exporting the public key from the Brocade switch to my SFTP server (Cerberos).
The Brocade switch is a 5480 with fw 7.3.1a (trying to upgrade it using SFTP..)
I follow the below procedure in the Brocade switch. I successfully create the key pair in the following procedure (step 4).
Configuring outgoing SSH authentication
After the allowed-user is configured, the remaining setup steps must be completed by the allowed-user. Use the following procedure to configure outgoing SSH authentication:
  1. Log in to the switch as the default admin.
  2. Change the allowed-user’s permissions to admin, if applicable.
    switch:admin> userconfig --change username -r admin
    where the username variable is the name of the user who can perform SSH public key
    authentication, and who can import, export, and delete keys.
  3. Set up the allowed-user by typing the following command:
    switch:admin> sshutil allowuser username
  4. Generate a key pair for switch-to-host (outgoing) authentication by logging in to the switch as the
    allowed user and entering the sshUtil genkey command. You may enter a passphrase for additional security. Example of generating a key pair on the switch
                         switch:alloweduser> sshutil genkey
                         Enter passphrase (empty for no passphrase):
                         Enter same passphrase again:
                         Key pair generated successfully.
  5. Export the public key to the host by logging in to the switch as the allowed-user and entering the sshUtil exportpubkey command to export the key.
    Example of exporting a public key from the switch
                         switch:alloweduser> sshutil exportpubkey
                         Enter IP address:192.168.38.244
                         Enter remote directory:~auser/.ssh
                         Enter login name:auser
                         Password:
                         public key out_going.pub is exported successfully.
  6. Append the public key to a remote host by logging in to the remote host, locating the directory where authorized keys are stored, and appending the public key to the file.
    You may need to refer to the host’s documentation to locate where the authorized keys are stored.
  7. Test the setup by using a command that uses SCP and authentication, such as firmwareDownload
    or configUpload .
In step 5, I get the following response on the switch: "Failed to export public key"
I need to clarify a few things:
What should I enter for the remote directory ? The Cerberos SFTP server is on a Windows server. I enter the name of a empty folder inside the ftproot folder, called ssh. The admin user has full access to ftproot.
I also tried ~ssh  and ~admin/.ssh as names for the remote directory.
Attached below is the log in the Cerberos SFTP-server. As you can see, the Brocade switch closes the connection:
2017/11/07 16:10:18       [53]       Incoming connection request on SSH interface 10 at 0.0.0.0
2017/11/07 16:10:18       [53]       SSH SFTP connection request accepted from 0.0.0.1
2017/11/07 16:10:18       [53]       Client Identification: SSH-2.0-OpenSSH_6.2
2017/11/07 16:10:18       [53]       Algorithm negotiation complete: Proceeding with key exchange
2017/11/07 16:10:18       [53]       Kex: 'ecdh-sha2-nistp256' Host Key: 'ssh-rsa' C2S : 'aes128-ctr, hmac-md5, none' S2C : 'aes128-ctr, hmac-md5, none'
2017/11/07 16:10:18       [53]       SSH key bits: 2048
2017/11/07 16:10:18       [53]       ECDH Key size: 256
2017/11/07 16:10:18       [53]       CCipher::init: Set key length (16 -> 32)
2017/11/07 16:10:18       [53]       CCipher::init: Set key length failed (16 -> 32) : invalid key length
2017/11/07 16:10:18       [53]       All keys derived
2017/11/07 16:10:18       [53]       Using new keys for sending data to the client
2017/11/07 16:10:18       [53]       The client closed the connection
2017/11/07 16:10:18       [53]       Connection terminated
 Could it be that the Cerberos SFTP-server has too high encryption requirements? I have opened up for all possibilities there. Is there perhaps something I can do on the Brocade switch?
Broadcom Moderator
Re: Public key export problem from Brocade 5480 switch
Hi atledale2,
if the user in cerberos sftp server call admin, have for example home directory in cerberos c:\sftp\admin, and you have created an empty folder called ssh in there (c:\sftp\admin\ssh),  in  sshutil exportpubkey for directory, I would try "/ssh" or even "."  - sftp server should only make available for all setup user a home directory.
New Contributor
hi, Thanks for answer. But it didn@t make a difference. Same error in Cerberus SFTP server (see log in first post). I also created a new FTP user with new home folder. Per default it wil place the file in the home folder if you  just specify specify file.txt .
If you want to specify a folder called ssh, you just write it like this: /ssh/filename.txt.
But in both cases, the Brocade client is terminating the connection after key negotiation has succeeded. Strange...
What I am testing is the upload function with configupload command.
Broadcom Moderator
Hi @atledale2,
I just did a quick install on my laptop and cerberus sftp server support sftp, but not scp :-(
And the ssh exportkey uses scp to copy the public key over to server.
So you need to export the key via scp to another server.
Or login via root and get the public key from the file /root/.ssh/id_rsa.pub (if you generated a rsa private key).
Under FOS 7.4.1e, configupload/download/supportsave/firmwaredownload support sftp and you can user sftp with public keys.
New Contributor
hi,
Thanks for your efforts. I will instead do this with normal FTP.
But, for the future:
What you mean by "Or login via root and get the public key from the file /root/.ssh/id_rsa.pub (if you generated a rsa private key)."?
I believe I didn@t create a public key, just the public key created using the above procedure. I don@t need a private key either for my purpose.
and
Do you know if the fw I get after upgrade will support scp? (FOS 7.4.1d)
Best regards,
Atle
Broadcom Moderator
Hi,
by "Or login via root and get the public key from the file /root/.ssh/id_rsa.pub (if you generated a rsa private key)." i mean:
1. When you run the "sshUtil genkey" the switch generate a switch private and public keys which are stored as stored in /root/.ssh/ as id_rsa (private) and id_rsa.pub for your version of FOS (and assume a RSA and not DSA key)
2. When login as root, the you can take a copy of the public key (which it is what "sshutil exportpubkey" does)  /root/.ssh/id_rsa.pub and append to the authorized_keys to run supportsave, configupload from the switch to a server (with scp / sftp).
