Anonymous
Accepted Solution
Problem with web gui access to Brocade 5450
Hi to all, I nee help.
We has BC Fujitsu BX900 with two Brocade 5450 SAN switches. Also we use the BNA. A few days ago I found an error message "Switch unreachable since 17.11.13 11:23" in BNA Console. But problems with the equipment that is connected through the switch was not found. I tried to login via the web interface, but issued a browser error "Internet Explorer cannot display the webpage" I tried to login using Mozilla, but got the same error. However, the IP address of a this SAN switch pinged and I can access it via ssh. Please help to restore access to the web interface of switch
Anonymous
Re: Problem with web gui access to Brocade 5450
This might be due to the http daemon services that is stale.
Log in to the switch as root.
Run /fabos/libexec/webdconfigure
http attributes (yes, y, no, n): [no] y
        HTTP Restart (yes, y, no, n): [no] y
        HTTP enabled (yes, y, no, n): [yes]
        ErrorLog Enabled (yes, y, no, n): [no]
        AccessLog Enabled (yes, y, no, n): [no]
        SSLLog Enabled (yes, y, no, n): [no]
        HTTP Port: (1..60000) [80]
        Secure HTTP Port: (1..60000) [443]
        HTTP IsAlive Check Enabled (yes, y, no, n): [yes]
        HTTP Max HeapSize: (256..1024) [512]
  webtools attributes (yes, y, no, n): [no]
  cal attributes (yes, y, no, n): [no]
This should restart the http services.
You can issue ps -ef |grep http to view the services.
If this doesnt resolve the issue you should be able to run a "hareboot" non-disruptively.
Cheers.
Anonymous
Thank you!
hareboot command helped me.
