Anonymous
Problem with replace SFP in 4100. In two diferentes switches.
I hope get me your help.
A few days ago,  was necessary to replace 3 "SFP" in 2 Swicth 4100.
When  put the SFP's new, in  the GUI,  these are disabled.
After run Supportshow command on both switch, the port register  the following estatus:
port 21: Can not get serial data.
We again replace the SFP for the same part number and the result is the same in both switch.
We apply enabled command but this not change.
There any similar problem or sugestion
External Moderator
Re: Problem with replace SFP in 4100. In two diferentes switches.
which Fabric OS Release is loaded in the both switches ?
Post here the outpot from "switchshow" and the screenshot from port status from the webtool.
TechHelp24
Anonymous
Tks.
This output is the one Switch, the problem is in the port 23.
The Fabric OS is
Version:
Kernel:     2.6.14.2
Fabric OS:  v6.1.0d
Made on:    Mon Jul 28 17:05:07 2008
Flash:     Sun Aug 3 10:48:30 2008
BootProm:   4.6.6
switchshow:
switchName: san1
switchType: 32.0
switchState: Online
switchMode: Native
switchRole: Subordinate
switchDomain: 1
switchId: fffc01
switchWwn: 10:00:00:05:1e:35:f9:87
zoning:  ON (SAPH_tmp28Mar_san1san2)
switchBeacon: OFF
Area Port Media Speed State     Proto
  0   0   id    2G   Online           E-Port  (Trunk port, master is Port  1 )
  1   1   id    2G   Online           E-Port  10:00:00:05:1e:02:17:0b "san3" (Trunk master)
  2   2   id    2G   Online           F-Port  50:06:0e:80:04:76:04:18
  3   3   id    2G   Online           F-Port  50:06:0e:80:04:76:04:19
  4   4   id    2G   Online           F-Port  10:00:00:00:c9:4a:f7:8c
  5   5   id    2G   Online           F-Port  10:00:00:00:c9:4a:f8:1a
  6   6   id    2G   Online           E-Port  10:00:00:05:1e:02:17:0b "san3" (upstream)(Trunk master)
  7   7   id    2G   Online           E-Port  (Trunk port, master is Port  6 )
  8   8   id    2G   Online           F-Port  50:06:0e:80:04:76:04:59
  9   9   id    2G   Online           F-Port  50:06:0e:80:04:76:04:5a
10  10   id    2G   Online           F-Port  50:06:0e:80:04:76:04:5b
11  11   id    2G   Online           F-Port  50:06:0e:80:04:76:04:78
12  12   id    2G   Online           F-Port  21:00:00:e0:8b:82:1d:79
13  13   id    2G   Online           F-Port  10:00:00:00:c9:4a:f8:fa
14  14   id    2G   Online           F-Port  10:00:00:00:c9:4a:f8:82
15  15   id    2G   Online           F-Port  21:01:00:e0:8b:a2:62:7a
16  16   id    2G   Online           F-Port  50:06:0e:80:04:76:04:7a
17  17   id    2G   Online           F-Port  50:06:0e:80:04:76:04:38
18  18   id    2G   Online           F-Port  50:06:0e:80:04:76:04:39
19  19   id    2G   Online           F-Port  50:06:0e:80:04:76:04:3a
20  20   id    2G   No_Light
21  21   id    2G   No_Light
22  22   id    2G   Online           F-Port  21:01:00:e0:8b:3f:62:6c
23  23   id    2G   Port_Flt         Disabled
24  24   id    2G   Online           F-Port  50:06:0e:80:04:76:04:1a
25  25   id    2G   Online           F-Port  50:06:0e:80:04:76:04:1b
26  26   id    2G   Online           F-Port  50:06:0e:80:04:76:04:58
27  27   id    2G   Online           F-Port  50:06:0e:80:04:76:04:79
28  28   id    2G   Online           F-Port  21:00:00:e0:8b:82:26:78
29  29   id    2G   Online           F-Port  21:00:00:e0:8b:1f:62:6c
30  30   id    2G   Port_Flt         Disabled
31  31   id    2G   Online           F-Port  21:00:00:e0:8b:1f:94:65
real 0m0.213s
user 0m0.170s
sys 0m0.020s
And this output is the next 4100, the problem is in the ports 15.
switchshow:
switchName: san8
switchType: 32.0
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 8
switchId: fffc08
switchWwn: 10:00:00:05:1e:35:2a:bd
zoning: ON (SAN_2)
switchBeacon: OFF
0 0 id 2G Online E-Port 10:00:00:05:1e:34:f2:8e "san6" (downstream)(Trunk master)
1 1 id 2G Online E-Port (Trunk port, master is Port 0 )
2 2 id 2G Online L-Port 1 public
3 3 id 2G Online F-Port 21:00:00:e0:8b:82:e3:7a
4 4 id 2G Online F-Port 50:06:0e:80:04:29:e2:70
5 5 id 2G Online F-Port 10:00:00:00:c9:4a:f7:fa
6 6 id 2G Online E-Port (Trunk port, master is Port 0 )
7 7 id 2G Online E-Port 10:00:00:05:1e:34:f2:8e "san6" (Trunk master)
8 8 id 2G Online F-Port 50:06:0e:80:04:29:e2:10
9 9 id 2G Online F-Port 50:06:0e:80:04:29:e2:12
10 10 id 2G Online F-Port 50:06:0e:80:04:29:e2:14
11 11 id 2G Online F-Port 50:06:0e:80:04:29:e2:16
12 12 id 2G Online F-Port 21:01:00:e0:8b:3f:30:04
13 13 id 2G Online F-Port 21:01:00:e0:8b:3f:63:6c
14 14 id 2G Online F-Port 21:01:00:e0:8b:3f:8e:65
15 15 id 2G Port_Flt Disabled
16 16 id 2G Online F-Port 50:06:0e:80:04:29:e2:30
17 17 id 2G Online F-Port 50:06:0e:80:04:29:e2:34
18 18 id 2G Online F-Port 50:06:0e:80:04:29:e2:32
19 19 id 2G Online F-Port 50:06:0e:80:04:29:e2:36
20 20 id 2G Online F-Port 21:00:00:e0:8b:1f:5d:6c
21 21 id 2G Online F-Port 21:00:00:e0:8b:09:67:63
22 22 id 2G Online F-Port 21:01:00:e0:8b:a2:62:79
23 23 id 2G Online F-Port 21:01:00:e0:8b:a2:dd:7a
24 24 id 2G Online F-Port 50:06:0e:80:04:29:e2:50
25 25 id 2G Online F-Port 50:06:0e:80:04:29:e2:54
26 26 id 2G Online F-Port 50:06:0e:80:04:29:e2:52
27 27 id 2G Online F-Port 50:06:0e:80:04:29:e2:56
28 28 id 2G No_Light
29 29 id 2G Online F-Port 21:00:00:1b:32:0e:6e:f5
30 30 id 2G Online F-Port 10:00:00:00:c9:4a:f7:f0
31 31 id 2G Online F-Port 10:00:00:00:c9:4a:f9:b8
real 0m0.180s
user 0m0.150s
sys 0m0.030s
And there other Switch  and the ports are 12 and 28.
switchshow:
switchName: san10
switchType: 32.0
switchState: Online
switchMode: Native
switchDomain: 9
switchId: fffc09
switchWwn: 10:00:00:05:1e:35:37:78
zoning: ON (cubo6_bkp)
switchBeacon: OFF
0 0 id 2G Online F-Port 50:01:04:f0:00:81:ea:00
1 1 id 2G Online L-Port 1 public
3 3 id 2G Online L-Port 1 public
4 4 id 2G No_Light
5 5 id 2G Online F-Port 50:06:0e:80:04:29:e2:3b
6 6 id 2G No_Light
7 7 id 2G No_Light
8 8 id 2G Online L-Port 1 public
9 9 id 2G Online L-Port 1 public
10 10 id 2G No_Light
11 11 id 2G Online F-Port 21:00:00:e0:8b:1f:4b:04
12 12 id 2G Port_Flt Disabled
13 13 id 2G No_Light
14 14 id 2G Online F-Port 21:01:00:e0:8b:a2:bf:78
15 15 id 2G Online F-Port 21:00:00:e0:8b:82:21:8e
16 16 id 2G Online F-Port 21:01:00:e0:8b:3f:4b:04
17 17 id 2G Online F-Port 21:00:00:e0:8b:1e:a0:f0
18 18 id 2G Online F-Port 21:01:00:e0:8b:3e:a0:f0
19 19 id 2G Online F-Port 50:06:0e:80:04:29:e2:66
20 20 id 2G Online F-Port 21:01:00:e0:8b:a2:e9:78
21 21 id 2G Online F-Port 21:00:00:e0:8b:82:52:77
22 22 id 2G Online F-Port 21:00:00:e0:8b:82:e9:78
23 23 id 2G Online F-Port 21:00:00:e0:8b:1f:ca:63
24 24 id 2G Online F-Port 21:00:00:e0:8b:1f:31:03
25 25 id 2G Online F-Port 21:01:00:e0:8b:3f:31:03
26 26 id 2G Online L-Port 1 public
27 27 id 2G No_Light
28 28 id 2G Port_Flt Disabled
29 29 id 2G Online F-Port 50:06:0e:80:04:29:e2:76
30 30 id 2G Online F-Port 21:01:00:e0:8b:3f:09:64
31 31 id 2G Online F-Port 21:00:00:e0:8b:1f:57:6c
real 0m0.180s
user 0m0.160s
sys 0m0.030s
Anonymous
All has the same OS version.
External Moderator
Hi know i similary Error from a Old FOS 5.x when the Port was set as E_Port
Try please follow, check with "portshow" the current port state, set the port as disable "portdisable" and try "portcfgeport" now, wait a couple of minute and set the port enable now with "portenable"
make sure the port is not set as persistent disable.
what happened ?
Create a screenshot before you try the port comamnd and after, post please both screenshot from this Port switch/GUI here.
TechHelp24
Anonymous
Tks.
In the next hours this action be apply.
I send the input .
Tks.
Super Contributor
Any news here ?
Anonymous
No yet,, probably we apply the sugestion  in the next friday at night.
I send the resoult.
