Anonymous
Problem with merging switches in a single fabric
Hello.
My company has 2 switches Brocade OEM (IBM 16B-2005 and 32B-2005) with Fabric OS 5.1.0b
We want to merge those switches in one fabric without using ISL trunking capability.
I run Merge Check Wizzard in Fabric Manager and it shows no errors.
The problem is that when I connect one port in one switch with one port in the other switch, the state of the port in one switch becomes "segmented" and the reason is "No fabric license".
The License tab in Web Admin Tool on both switches shows a licence for fabric.
Is there any other licenses we must purchase, or is it something that we did not do well?
External Moderator
Re: Problem with merging switches in a single fabric
cristiani,
heve you set of both switch the correct PID (1 is correct ) and different Domain ID ? example: the 32B have ID 1 and the 16B have ID 2.
Trunking License is not requiered to connect the both switch.
TechHelp24
TechHelp24
Anonymous
Setting different domain IDs was the first thing to do. Merge Check Wizzard confirmed to me that there are no problems with software configuration
External Moderator
Please capture trough the CLI with the command "fabricshow" and "switchshow" the output from both switch and post here
TechHelp24
Anonymous
Here are the outputs:
R15_FC_SW1:admin> fabricshow
Switch ID Worldwide Name Enet IP Addr FC IP Addr Name
2: fffc02 10:00:00:05:1e:04:09:5a 10.168.2.101 0.0.0.0 >"R15_FC_SW1"
R15_FC_SW1:admin> switchshow
switchName: R15_FC_SW1
switchType: 34.0
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 2
switchId: fffc02
switchWwn: 10:00:00:05:1e:04:09:5a
zoning: ON (Productie)
switchBeacon: OFF
Area Port Media Speed State
0 0 id N4 Online F-Port 10:00:00:00:c9:5c:c1:42
1 1 id N4 Online F-Port 10:00:00:00:c9:59:ca:ca
2 2 id N4 Online F-Port 21:00:00:e0:8b:93:ce:7a
3 3 id N4 Online F-Port 21:00:00:e0:8b:93:c1:7b
4 4 id N4 Online F-Port 20:15:00:a0:b8:26:a1:d4
5 5 id N4 Online F-Port 20:25:00:a0:b8:26:a1:d4
6 6 id N4 Online F-Port 20:35:00:a0:b8:26:a1:d4
7 7 id N4 Online F-Port 20:45:00:a0:b8:26:a1:d4
8 8 id N4 Online F-Port 10:00:00:00:c9:6d:6b:f2
9 9 -- N4 No_Module
10 10 -- N4 No_Module
11 11 -- N4 No_Module
12 12 -- N4 No_Module
13 13 id N4 Online E-Port segmented,(No Fabric License)
14 14 -- N4 No_Module
15 15 -- N4 No_Module
SW1-R13:admin> fabricshow
1: fffc01 10:00:00:05:1e:05:01:02 10.168.2.121 0.0.0.0 >"SW1-R13"
SW1-R13:admin> switchshow
switchName: SW1-R13
switchType: 32.0
switchState: Online
switchMode: Native
switchDomain: 1
switchId: fffc01
switchWwn: 10:00:00:05:1e:05:01:02
switchBeacon: OFF
0 0 id N4 Online F-Port 20:14:00:a0:b8:2a:07:fc
1 1 id N4 Online F-Port 20:24:00:a0:b8:2a:07:fc
2 2 id N4 Online F-Port 20:34:00:a0:b8:2a:07:fc
3 3 id N4 Online F-Port 20:44:00:a0:b8:2a:07:fc
4 4 id N4 Online F-Port 10:00:00:00:c9:63:80:6e
5 5 id N4 Online F-Port 10:00:00:00:c9:63:3b:6a
6 6 id N4 Online F-Port 10:00:00:00:c9:6d:67:94
7 7 id N4 Online F-Port 10:00:00:00:c9:6a:d1:51
8 8 id N4 Online F-Port 50:01:10:a0:00:18:53:7a
9 9 id N4 Online F-Port 50:01:10:a0:00:18:53:1a
10 10 id N4 Online F-Port 10:00:00:00:c9:6a:eb:ae
13 13 id N4 Online E-Port segmented,(disabled E_Port)
16 16 -- N4 No_Module
17 17 -- N4 No_Module
18 18 -- N4 No_Module
19 19 -- N4 No_Module
20 20 -- N4 No_Module
21 21 -- N4 No_Module
22 22 -- N4 No_Module
23 23 -- N4 No_Module
24 24 -- N4 No_Module
25 25 -- N4 No_Module
26 26 -- N4 No_Module
27 27 -- N4 No_Module
28 28 -- N4 No_Module
29 29 -- N4 No_Module
30 30 -- N4 No_Module
31 31 -- N4 No_Module
External Moderator
cristian,
is very suspect, but this is not a Fabric License Problem. I note follow, the 16B have a NPIV License installed, is here probable this port NPIV enable set ?
execute "portcfgdefault" of both port/switch disconnect the ISL cable and reconfig this both port now.
Use please a different Port Number of both switch, after the Port's are configured connect the both switch.
TechHelp24
Anonymous
So I removed the cable between switches, run portcfgdefault on port 11/switch B16 and switch port12/B32 and the problem is still there.
I removed NPIV licence on switch B32 (only that one had that kind of licence) and the error is the same.
Maybe there is another procedure to follow for fabric merging. Do you have a link for such document?
I found somewhere that the switch that I'm adding to one fabric must not have any zone configurations. Connecting the 2 switches toghether, which fabric will be the "master" so to speak?
External Moderator
Cristian,
this is another story.
--->>> I found somewhere that the switch that I'm adding to one fabric must not have any zone configurations.
Yes, and this is correct. Zoning and Alias will be Merging automatically to the other switch. If you have in the new switch this configured , disconnect first the switch and delete the config.
But here remain the segmented Problem, probable is this solved after you delete the config.
--->>> Do you have a link for such document?
Fabric merging is a simple of the World, i don't know any Link, but will see i have some DOC and upload here.
TechHelp24
TechHelp24
