Anonymous
Problem with enabling ISL Trunk
Just added an BROCADE switch to IBM Bladecenter.
I need to set up an ISL trunk between bladecenter SAN switch (8Gb) and external BROCADE SAN16B Switch (4Gb).
Error message is "Speed mismatch / Incompatible Vendor" when port is enabled.
SFP is 4gb i both ends and port speed is set to 4gb, still no go.
Bladechassis SAN Switch is OS=v 6.3.1b and External SAN16B is v6.1.0c.
Does different Fabric OS have any impact on ISL Trunk?
Port is enabled and licensed.
Anonymous
Re: Problem with enabling ISL Trunk
Hi
did you try with auto-negociated speed on both side ?
Please provide which ports are in use and portcfgshow on both side
Are you using Access gateway mode on bladecenter switch ?
Kind regards,
david
Anonymous
Hi,
Also tried auto-negociate, no luck.
Not using Access Gateway.
Trunk is from Port0 Bladechassis switch --> Port4 External switch
Blade Switch:
xxxxxxxx:USERID> portcfgshow 0
Area Number:              0
Speed Level:              4G
Fill Word:                1(Arbff-Arbff)
AL_PA Offset 13:          OFF
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             ON
Disabled E_Port           OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
Persistent Disable        OFF
NPIV capability           ON
QOS E_Port                AE
Port Auto Disable:        OFF
Rate Limit                OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
xxxxxxxx:admin> portcfgshow 4
Area Number:              4
Speed Level:              4G
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             ON
Disabled E_Port           OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
NPIV capability           ON
QOS E_Port                OFF
Anonymous
I don't see anything wrong here ... Is this a shortwave link ? How much distance between switchs ?
Could you provide sfpshow on ports ?
Or attach supportshows to have all information.
Kind regards,
david
Anonymous
Distance is 8meters.
Bladechassis switch
Blade_SW2:USERID> sfpshow 0
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 150c402000000000 100,200,400_MB/s M5,M6 sw Inter_dist
Encoding:    1    8B10B
Baud Rate:   43   (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u:  15   (units 10 meters)
Length 62.5u:7    (units 10 meters)
Length Cu:   0    (units 1 meter)
Vendor Name: AVAGO
Vendor OUI:  00:17:6a
Vendor PN:   AFBR-57R5AEZ
Vendor Rev:
Wavelength:  850  (units nm)
Options:     001a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   A90818WEZH
Date Code:   080429
DD Type:     0x68
Enh Options: 0xf0
Status/Ctrl: 0x90
Alarm flags = 0x5, 0x0
Warn Flags = 0x5, 0x0
                                          Alarm                  Warn
                                      low        high       low         high
Temperature: 26      Centigrade     -40         100        -10         85
Current:     0.000   mAmps          2.000       10.000     2.000       10.000
Voltage:     3281.3  mVolts         2700.0      3900.0     2970.0      3630.0
RX Power:    -5.8    dBm (261.5 uW) 0.0    uW   6550.0 uW  49.0   uW   1100.0 uW
TX Power:    -inf    dBm (0.0   uW) 50.0   uW   700.0  uW  100.0  uW   600.0  uW
Blade_SW2:USERID>
External switch
HIKT-SAN-SW2:admin> sfpshow 4
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Name: AVAGO
Vendor Rev:
BR Max:      0
BR Min:      0
Serial No:   A90818WEZC
Date Code:   080429
Temperature: 30 Centigrade
Current:     5.834 mAmps
Voltage:     3331.6 mVolts
RX Power:    -inf  dBm (0.0 uWatts)
TX Power:    -6.2  dBm (238.9 uWatts)
Anonymous
Try to use Brocade branded SFP on 8G embedded switch. Since 8G hardware, sfp matrix has been dramatically reduced and I'm not sure avago 4G SFP is supported on 8G Brocade switches.
Hope this helps
Kind regards,
david
