New Contributor
Problem with commands run under a user defined role (FOS 8.1.2a)
Hi guys
I stumbled upon a strange problem when using a user in a user defined role.
I ceated a new user defined role which is basically a copy of the 'user' role with the addition of 2 extra permissions allowing cedrtain commands to be used.
For testing purposes I logged in with the new user and tested all the new commands plus somes 'old' ones - so far so good.
Now, we have a script thats runs from outside our switches and executes certain commands like "switchshow" or "version", via SSH, collects the output and puts it into a database. Since we changed to gropu of the user from 'user' to our newly created user defined gruop I get the following problem when running the script:
ERROR: Failed to get switch info switchshow: Could not chdir to home directory /fabos/users/udrole: Permission denied
rbash: /fabos/users/udrole/.bashrc: Permission denied
rbash: switchshow: command not found
I know there was an error regarding the same directory a while ago which was fixed in 8.1.0 (DEFECT000618708).
But maybe it is similar to this fixed defect.
Any ideas are appreciated.
Cheers
Peter
Regular Contributor
Re: Problem with commands run under a user defined role (FOS 8.1.2a)
I would recommend running the script manually from the same location the script is located. Meaning, line by line.
I use a custom VBA script and on occassion I find that the formatting of the "send" needs to be adjusted.
