Anonymous
Problem with GigE ports on 7500E
I have just installed two Brocade 7500E devices and used Cisco SFPs in ge0 and ge1.  I cannot get these to come online even though the 7500E shows them as enabled.
The are showing no light on the SFPs at all.  Any ideas?
fes01:admin> switchshow
switchName:     fes01
switchType:     46.2
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   62
switchId:       fffc3e
switchWwn:      10:00:00:05:1e:c1:6b:5e
zoning:         OFF
switchBeacon:   OFF
FC Router:      OFF
FC Router BB Fabric ID: 1
Index Port Address Media Speed State     Proto
  0   0   3e0000   id    N4   Online      FC  F-Port  50:06:0e:80:05:6f:15:05
  1   1   3e0100   id    N4   No_Light    FC
  2   2   3e0200   id    N4   No_Light    FC  Disabled (Persistent)
  3   3   3e0300   id    N4   No_Light    FC  Disabled (Persistent)
  4   4   3e0400   --    N4   No_Module   FC  Disabled (Persistent)
  5   5   3e0500   --    N4   No_Module   FC  Disabled (Persistent)
  6   6   3e0600   --    N4   No_Module   FC  Disabled (Persistent)
  7   7   3e0700   --    N4   No_Module   FC  Disabled (Persistent)
  8   8   3e0800   --    N4   No_Module   FC  Disabled (Persistent)
  9   9   3e0900   --    N4   No_Module   FC  Disabled (Persistent)
10  10   3e0a00   --    N4   No_Module   FC  Disabled (Persistent)
11  11   3e0b00   --    N4   No_Module   FC  Disabled (Persistent)
12  12   3e0c00   --    N4   No_Module   FC  Disabled (Persistent)
13  13   3e0d00   --    N4   No_Module   FC  Disabled (Persistent)
14  14   3e0e00   --    N4   No_Module   FC  Disabled (Persistent)
15  15   3e0f00   --    N4   No_Module   FC  Disabled (Persistent)
16  16   3e1000   --    --   Offline     VE  Disabled (Persistent)
17  17   3e1100   --    --   Offline     VE  Disabled (Persistent)
18  18   3e1200   --    --   Offline     VE  Disabled (Persistent)
19  19   3e1300   --    --   Offline     VE  Disabled (Persistent)
20  20   3e1400   --    --   Offline     VE  Disabled (Persistent)
21  21   3e1500   --    --   Offline     VE  Disabled (Persistent)
22  22   3e1600   --    --   Offline     VE  Disabled (Persistent)
23  23   3e1700   --    --   Offline     VE  Disabled (Persistent)
24  24   3e1800   --    --   Offline     VE  Disabled (Persistent)
25  25   3e1900   --    --   Offline     VE  Disabled (Persistent)
26  26   3e1a00   --    --   Offline     VE  Disabled (Persistent)
27  27   3e1b00   --    --   Offline     VE  Disabled (Persistent)
28  28   3e1c00   --    --   Offline     VE  Disabled (Persistent)
29  29   3e1d00   --    --   Offline     VE  Disabled (Persistent)
30  30   3e1e00   --    --   Offline     VE  Disabled (Persistent)
31  31   3e1f00   --    --   Offline     VE  Disabled (Persistent)
     ge0  id    1G   No_Sync   FCIP
     ge1  id    1G   No_Sync   FCIP
fes01:admin>
fes01:admin> portshow ge0
Eth Mac Address: 00.05.1e.c1.6b.42
Port State: 2   Offline
Port Phys:  5   No_Sync
Port Flags: 0x4001       PRESENT LED
Port Speed: 1G
fes01:admin> portshow ge1
Eth Mac Address: 00.05.1e.c1.6b.43
Port Speed: 1G
fes01:admin>
fes01:admin> sfpshow ge0
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 0000000001000000   id
Encoding:    1    8B10B
Baud Rate:   13   (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u:  55   (units 10 meters)
Length 62.5u:27   (units 10 meters)
Length Cu:   0    (units 1 meter)
Vendor Name: CISCO-FINISAR
Vendor OUI:  00:90:65
Vendor PN:   FTRJ8519P1BNL-C5
Vendor Rev:
Wavelength:  850  (units nm)
Options:     0012 Loss_of_Sig,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   FNS1003Q0HY
Date Code:   060117
DD Type:     0x8
Enh Options: 0x0
fes01:admin>
fes01:admin> sfpshow ge1
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:
BR Max:      0
BR Min:      0
Serial No:   FNS0952J491
Date Code:   051223
DD Type:     0x8
Enh Options: 0x0
fes01:admin>
External Moderator
Re: Problem with GigE ports on 7500E
Cisco SFP are not supported by Brocade, you must replaced the SFP.
TechHelp24
Anonymous
I am having the same problem but using different SFP's, where can I find out what is supported. I tried reseating them and a reboot of the router, but not able to bring them online
Name    Value
Vendor Name    FINISAR CORP.
Vendor OUI    00:90:65
FC Speed    100,200,400_MB/s
Distance    Long_dist
Name    Value
Vendor PN    FTLF1324P2BTV-B1
Vendor Rev    A
Serial No    PH52YKR
Date Code    100127
Media Form Factor    SFP
Connector    LC
Wave Length    1310
Encoding    8B10B
Diagnostics
        Xceiver Temp    45 Centigrade
        TX Power    3.7 uWatts   (5.682 dBm)
        RX Power    0.0 uWatts
admin> sfpshow ge1
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 1501001202000000 100,200,400_MB/s SM lw Long_dist
Encoding:    1    8B10B
Baud Rate:   42   (units 100 megabaud)
Length 9u:   4    (units km)
Length 9u:   40   (units 100 meters)
Length 50u:  0    (units 10 meters)
Length 62.5u:0    (units 10 meters)
Vendor Name: FINISAR CORP.
Vendor PN:   FTLF1324P2BTV-B1
Vendor Rev:  A
Wavelength:  1310 (units nm)
Options:     003a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   PH52YKR
Date Code:   100127
Temperature: 45 Centigrade
Current:     0.382 mAmps
Voltage:     3319.4 mVolts
RX Power:    0.0 uWatts
TX Power:    3.7 uWatts
admin> portshow ge1
Eth Mac Address: 00.05.1e.c1.34.d1
Port Flags: 0x1  PRESENT
Port Speed: 1G
Super Contributor
Jcascanette,
you Use here
--->>>admin> sfpshow ge1
Trunkated
--->>>Wave Length    1310
1310, are LX SFP, Such SFP are supported, but  assume you have set the Port vale wrong.
Testing with another Standard SX Shortwave 850 SFP
and making sure the port is Enabled.
Post the "switchshow" output here please.
