Anonymous
Problem to zoning new FC4-32 card.
Recently we installed a new FC4-32 ports in our Brocade 48000, but even as the cards and ports are recognized and enabled, ports are not available to zoning.  Another FC4-32 card is also waiting to be installed as soon as we solve these inconvenience.-
Do you know if in addition to physical installation, any other command is required to be able to use these ports?
Thank you for your help..
Anonymous
Re: Problem to zoning new FC4-32 card.
Please run chassisshow and slotshow
In addition you can run slotpoweroff and slotpoweron commands too check if the blade will came online correctly.
I hope this helps,
Andreas
Anonymous
Thank for your support Andreas, I´m sending the output of chassishow and slotshow, and also the member selection list for port zoning, after the slotpoweroff and slotpoweron was applied, but still not showed to allow selection of these ports.
see document attached.
