Anonymous
Re: Problem for access webtools from internet explorer or firefox with JRE 1.7!
Open the java.security file which is located in your client machine's Java/JRE installed directory (jre/lib/security/java.security).
Look for this line:
jdk.certpath.disabledAlgorithms=MD2, RSA keySize < 1024
Change 1024 to 256 and save.
That worked for me.
Valued Contributor
I agree with @ataylor, it also worked for me.
Anonymous
Helped me out, thanks for the info.
Ive been going mad with this issue on a brand new Brocade 300
Anonymous
Hi, I've modified the number to 256 but i'm still can't access. Pls help............
Valued Contributor
Put the following, instead of what you have,  in the java.security file:
rgds
Anonymous
Have a look here:
http://erwinvanlonden.net/2013/12/brocade-webtools-and-java/
This might resolve your issue.
Regards,
Erwin
Anonymous
I tried all of the above and none worked but his did from this blog http://www.richardnichols.net/2012/08/arrrggh-java-security-cert-certificateexception-certificates-does-not-conform-to-algorithm-constraints/
JDK7 changed the default Java security settings to disable MD2 algorithm to sign SSL certificates.
BUT this can be re-enabled by editing JDK_HOME/jre7/lib/security/java.security and commenting out the following line:
... becomes ...
#jdk.certpath.disabledAlgorithms=MD2
Anonymous
I do faced this issue with Brocade 5300 and 300..
now it is resolved..
Thanks alot Ataylor :)
New Contributor
Thanks all for the detail on security that was already a first step to resolving my issues.
But now that I can access it it take about 3 to 7 minutes to open a webtool with JRE1.7 when it take about 30sec in JRE 1.6
My switch are still running 6.4.3d but got same behavior to 7.1.1 and running BNA 12.0.3
Anyone did get same issue ?
Or did you found a way to force BNA to use the older version of JRE and not its own 1.7 version ?
External Moderator
sebastien,
most probable you issue refer follow defect, the defect is reported in FOS Release Notes 7.1.1c
Symptom:
With JRE 1.7.0 update 45, users will see a warning message when WebTools is launched through HTTPS and will not be able to launch WebTools from Network Advisor with prior to v12.1.4 Network advisor revisions
Defect 481199: Compatibility issues in Web Tools with JRE 7 Update 45
TechHelp24
