Anonymous
Pre requestie for Brocade 2005 - B32 firmware upgrade
Hi
We are Planning to upgrade Brocade 2005 - B32 (4100) from 5.2 to 6.2 .. We have few AIX servers are connected to that ..Do I need to do any compatibilty check Before proceed ( Like HBA , Multipath version etc) ...Please provide link or any doc for same
Thanks
External Moderator
Re: Pre requestie for Brocade 2005 - B32 firmware upgrade
See here, select Matrices to download Compatibility Matrix
http://www.brocade.com/solutions-technology/technology/compatibility/index.page
BTW. FOS Upgrade from 5.2.x to 6.2.x or higher is not allowed in One Step.
for details refer FOS Release Notes.
TechHelp24
Anonymous
Hi Tech
Thanks for upadate..I have checked the link and did nt find few HBA / Firmware version s  models for AIX ..Means they are not compatables
Please find details
Server HBADriverFirmware
acsaywg00010_fcs0AIX 5.3 TL1157045.3.11.4HS1.92A1
acsaywg00010_fcs1AIX 5.3 TL11280B5.3.11.4TS1.91A5
acsaywg00008_fcs0AIX 5.3 TL1157595.3.11.4BS2.10X8
acsaywg00008_fcs1AIX 5.3 TL1157595.3.11.4BS2.10X8
acsaywg00011-fcs0AIX 5.3 TL11280B5.3.11.4TS1.90A4
acsaywg00011-fcs1AIX 5.3 TL1157045.3.11.4HS1.81X1
sd9wg003-fcs1 AIX 5.1 TL09Not Viewable5.1.0.67CS3.91X4
sd9wg003-fcs0 AIX 5.1 TL09Not Viewable5.1.0.67CS3.91X4
acsaywg00006_fcs3AIX 5.3 TL 1157745.3.11.4ZS2.71A2
acsaywg00006_fcs0AIX 5.3 TL 1157745.3.11.4ZS2.71A2
External Moderator
Hi,
I'm not familiary with AIX, but from the details you post here, this list only Drivers and FW release and not compatibility with any FOS x.y.z Release.
additional i don't know you corrent installed Driver and FW.
you should check as follow,
example: Driver and FW requierement for FOS 6.2.x with appropiate Switch Type.
keep in mind, IBM 2005-B32 is genuine Brocade 4100.
TechHelp24
Anonymous
Hi Thanks for update..
Is it madatory to check compatabilty before upgrade to other version..? if it is yes , please specify what are all the fields need to check..Thanks
