Anonymous
Please, help to fixed "No Performance statistics records were found matching the specified search criteria"
I try to use performance monitoring in Fabric manager. I already add SAN Device to monitor. Then I try to generate custom report. It show message "No Performance statistics records were found matching the specified search criteria". It cannot generate report. I find in Fabric Administrator Doc. Doc said this issue occue from critiria mismatch. anyway I try to use other generate report option. It still show same message. Please, help to recommend to fixed this issue.
