Anonymous
No_Module display in switch 200e
Hi,
can anyone help me
the other end fiber is connected to Sun SL500 tape library..
11 port i.e. connected to switch shows No_Module
i try to change fiber cable and removed sfp and connected back but still it display No_Module
kindly can any body help me..
Regards@Muneer
Anonymous
Re: No_Module display in switch 200e
It looks that the SFP is maybe not connected correctly into the switch or the SFP is dead.
Try to run sfpshow and post the output here.
Another option is that you use an other SFPs in port 11.
It look that you have one in port 12.
Please run as well the statsclear command and wait some minutes and run the porterrshow command to verify if the counters have changed.
I hope this helps,
Andreas
