Anonymous
Need assistance to skip control-C message on SAN switch
Hi ,
whenever login into the new switch using admin username & password asking to do "ctrl+c" or enter to processed.
DC_DC04_SW1 login: admin
Password:
Please change passwords for switch default accounts now.
Use Control-C to exit or press 'Enter' key to proceed.
Password was not changed. Will prompt again at next login
until password is changed.
DC_DC04_SW1:FID128:admin>
Now want to skip this message...
Note: after changing the all the passwords for the all the accounts also....
will help me to resolve this..
Regards
Seenivasan P
External Moderator
Re: Need assistance to skip control-C message on SAN switch
simple change the password for admin
TechHelp24
Anonymous
After changing admin password also am getting the same message...
Regards
Seenivasan P
Anonymous
The message clearly states switch default accounts, plural.
So only changing the admin account will not suffice, change root, factory and user as well
Anonymous
it's not recommended to change the root,factory,user passwords.
So any other way to skip this message ?
Anonymous
Source?
http://www.brocade.com/downloads/documents/html_product_manuals/FOS_AG_710/wwhelp/wwhimpl/js/html/wwhelp.htm#href=usermgmt.11.3.html
Directly above table 15
Table 15 lists the predefined accounts offered by Fabric OS that are available in the local-switch user database. The password for all default accounts should be changed during the initial installation and configuration of each switch.
Now go change the password to get rid of the message and as a bonus get a password, which is not longer one LMGTFY away
Contributor
If you really want to keep them, have you tried changing them back to the default after changing the passwords the first time?
I have not tested it but that might be a workaround.
Anonymous
Hi micm and dion,
it's working fine...Thanks for your assistance.
Regards
Seenivasan P
