Anonymous
NO fc connection DS-5000b after manual reboot, leds are not blinking
hello
from GUI leds are solid, all ports are online, zoning are defined, and switch seem to be normal, but switch has no FC conectivity,
is there any way to try to reset some state on this switch via cli, istead of powering off o rebooting from GUI,
i think that switch is failed but i would like to try everything before change it.
thanks
mc.
External Moderator
Re: NO fc connection DS-5000b after manual reboot, leds are not blinking
Have you access to the switch via CLI ? or from Serail Port ?
If yes, post Switch show output and make sure the switch is enabled.
TechHelp24
Anonymous
i do via cli
i have this from supportshow
switchshow:
switchName:UP_SWITCH
switchType:58.2
switchState:Online
switchMode:Native
switchRole:Principal
switchDomain:1
switchId:fffc01
switchWwn:10:00:00:05:1e:90:85:21
zoning:ON (Z__UPSWITCH)
switchBeacon:OFF
Area Port Media Speed State     Proto
  0   0   id    N4   Online           F-Port  50:06:01:60:3c:e0:1e:a7
  1   1   id    N4   Online           F-Port  50:06:01:69:3c:e0:1e:a7
  2   2   id    N4   Online           F-Port  50:01:43:80:06:2e:08:c8
  3   3   id    N4   Online           F-Port  50:01:43:80:03:be:d5:7c
  4   4   id    N4   Online           F-Port  50:01:43:80:03:be:d5:84
  5   5   id    N4   Online           F-Port  50:01:43:80:03:be:d5:18
  6   6   id    N4   Online           F-Port  50:01:43:80:03:be:d5:74
  7   7   id    N4   Online           F-Port  50:01:43:80:03:be:d5:20
  8   8   id    N4   Online           F-Port  50:01:43:80:03:be:d5:58
  9   9   id    N4   Online           F-Port  50:01:43:80:03:bf:f5:7c
10  10   id    N4   Online           F-Port  50:01:43:80:03:bf:f5:e0
11  11   id    N4   Online           F-Port  50:01:43:80:03:bf:f4:c4
12  12   id    N4   Online           F-Port  50:01:43:80:03:be:d5:90
13  13   id    N4   Online           F-Port  50:01:43:80:03:be:d5:24
14  14   id    N4   Online           F-Port  50:01:43:80:03:be:d5:78
15  15   id    N4   Online           F-Port  50:01:43:80:03:be:d5:9c
16  16   id    N4   No_Light
17  17   id    N4   Online           F-Port  50:01:43:80:07:29:f7:7c
18  18   id    N4   Online           F-Port  50:01:43:80:07:29:f5:44
19  19   id    N4   Online           F-Port  50:01:43:80:07:2a:0c:34
20  20   id    N4   Online           F-Port  50:01:43:80:07:2a:12:a8
21  21   id    N4   Online           F-Port  50:01:43:80:07:29:f5:e0
22  22   id    N4   Online           F-Port  50:01:43:80:07:29:f7:68
23  23   id    N4   Online           F-Port  50:01:43:80:07:29:f1:24
24  24   --    N4   No_Module        (No POD License) Disabled
supportshow groups enabled:
os         enabled
exception  enabled
port       enabled
fabric     enabled
services   enabled
security   enabled
network    enabled
portlog    enabled
system     enabled
extend     disabled
filter     disabled
perfmon    disabled
ficon      disabled
iswitch    enabled
asic_db    enabled
iscsi      enabled
ag         enabled
bin/cat /var/log/dmesg:
Linux version 2.6.14.2 (swrel@blc-2-1) (gcc version 3.4.6) #1 Tue Feb 5 15:18:23 PST 2008
ppc440_setup_arch(): Not setting the 100MBFull for eth1 on this SWBD58
cpld_init: platform (58) not supported
Brocade Silkworm port (C) 2002 MontaVista Software, Inc. (source@mvista.com)
On node 0 totalpages: 65536
  DMA zone: 65536 pages, LIFO batch:31
  Normal zone: 0 pages, LIFO batch:1
  HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: quiet
PID hash table entries: 2048 (order: 11, 32768 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 253824k available (2340k kernel code, 632k data, 108k init, 0k highmem)
Calibrating delay loop... 499.71 BogoMIPS (lpj=2498560)
Mount-cache hash table entries: 512
checking if image is initramfs...it isn't (bad gzip magic numbers); looks like an initrd
Freeing initrd memory: 2603k freed
NET: Registered protocol family 16
PCI: Probing PCI hardware
PCI: Cannot allocate resource region 0 of device 0000:00:00.0
SGI XFS with no debug enabled
IBM gpio driver version 06.12.06
SWBD Platform Driver v1.0: .
Config Silkworm
PPC 405 watchdog driver v0.51. (Timer driven)
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
ttyS0 at MMIO 0x0 (irq = 1) is a 16550A
ttyS1 at MMIO 0x0 (irq = 0) is a 16550A
io scheduler noop registered
RAMDISK driver initialized: 1 RAM disks of 50000K size 1024 blocksize
loop: loaded (max 8 devices)
PPC 4xx OCP EMAC driver, version 3.54
mal0: initialized, 4 TX channels, 2 RX channels
zmii0: bridge in RMII mode
eth0: emac0, MAC 00:05:1e:90:85:21
eth0: found Generic MII PHY (0x01)
emac1: can't find PHY!
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
cpld_ide_init_hwif_ports: dp=0, cp=0, hw=c1123f50
read cpld_data 0x84
Silkworm CE-2 CPLD ATA interface configured
Probing IDE interface ide0...
hda: STI Flash 8.0.0, CFA DISK drive
ide0 at 0xd301b1f0-0xd301b1f7,0xd301b3f6 on irq 28
hda: max request size: 128KiB
hda: 2001888 sectors (1024 MB), CHS=1986/16/63
hda: cache flushes not supported
hda: hda1 hda2
ATA polled-mode panic dumper on char-major-252.
mtdchar: write-caching enabled
silkworm: Using SWBD34 flash configuration
Boot flash: Found 1 x16 devices at 0x0 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
0: offset=0x0,size=0x20000,blocks=32
Creating 6 MTD partitions on "Boot flash":
0x00000000-0x00020000 : "bootenv0: boot environment (1)"
0x00020000-0x00040000 : "bootenv1: boot environment (2)"
0x00040000-0x00200000 : "prom0: boot prom (1)"
0x00200000-0x003c0000 : "prom1: boot prom (2)"
0x003c0000-0x003e0000 : "unused"
0x003e0000-0x00400000 : "bootsel: boot prom selector"
i2c /dev entries driver
IBM IIC driver v2.1
ibm-iic0: using standard (100 kHz) mode
ibm-iic1: using standard (100 kHz) mode
cpld_write_register: Cannot access CPLD. Initialization needed
iic1: Registered I2C mux callback for SWBD58
M41T11 Real-time-clock Driver v1.1
m41t11: Called to probe for bus IIC-0
m41t11: I2C Real-Time-Clock detected on iic0 addr 0x68
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
ip_tables: (C) 2000-2002 Netfilter core team
TCP bic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
ip6_tables: (C) 2000-2002 Netfilter core team
NET: Registered protocol family 17
RAMDISK: ext2 filesystem found at block 0
RAMDISK: Loading 2600KiB into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-done.
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem).
xfsshutdownhandler_module: module license 'unspecified' taints kernel.
hda: hda1 hda2
kjournald starting.  Commit interval 5 seconds
EXT3-super: c125a600 frblk 90720 cnt 90720 frino 120258 cnt 120258
EXT3 FS on hda1, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
hda: hda1 hda2
VFS: Mounted root (ext3 filesystem) readonly.
Trying to move old root to /initrd ... okay
Freeing unused kernel memory: 108k init
/bin/cat /etc/fstab:
/dev/root/ext3rw,noatime0 0
none/procprocdefaults0 0
none/dev/ptsdevptsmode=6200 0
/bin/cat /etc/mtab:
/dev/root / unknown rw 0 0
none /proc proc rw 0 0
none /dev/pts devpts rw,mode=620 0 0
none /tmp ramfs rw 0 0
/dev/hda2 /mnt ext3 rw,noatime 0 0
printing proc entries
/proc/cmdline:
quiet
/proc/cpuinfo:
processor: 0
cpu: 440GP Rev. C
revision: 4.129 (pvr 4012 0481)
bogomips: 499.71
machine: Brocade Silkworm440
plb bus clock: 133MHz
pci bus clock: 33MHz
uart clock: 0KHz (internal)
/proc/devices:
Character devices:
  1 mem
  4 ttyS
  5 /dev/tty
  5 /dev/console
  5 /dev/ptmx
10 misc
13 input
89 i2c
90 mtd
128 ptm
136 pts
241 swd
242 ham
243 fc
244 fc-switch
245 fabsys
246 fss_data
247 fss_mgmt
248 portlog
249 xprt
250 trace
251 raslog
252 ata_dumper
253 platform
254 mem_page
Block devices:
  1 ramdisk
  3 ide0
  7 loop
/proc/filesystems:
nodevrootfs
nodevbdev
nodevproc
nodevsockfs
nodevpipefs
nodevfutexfs
nodevtmpfs
nodevinotifyfs
nodevdevpts
ext3
ext2
nodevramfs
nodevnfs
xfs
nodevrpc_pipefs
