Anonymous
Multiple switches under web UI
Hello all,
Does anyone know how can I have multiple switches under Zone Administration?
I have three switches in the same fabric and only in one I can see all ports attached from the switches (switch1, switch3, and switch5), the other two only show the ports in that particular switch.
See attached file for some screenshots.
I appreciate if you guys can help!
Thanks!
Anonymous
Re: Multiple switches under web UI
is that a core-edge setup?which is the principal switch if that is the case?
Anonymous
Hi wrios,
With Fabric OS 6.x this functionality has moved from Web Tools to DCFM (Data Center Fabric Manager) and later on to BNA (Brocade Network Advisor). Both products offer a free "Professional" version that can manage one fabric at a time.
Also, Enhanced Group Management license is required on 8G and newer switches to properly integrate into DCFM/BNA.
Hope this helps,
Linar
Anonymous
Thanks for your reply.
I see, on the switch which I can see the three switches, the FOS running is 5.3.
I appreciate your help.
wrios.
