Turn on suggestions
Showing results for
08-30-2007 02:01 AM
Hi,
08-31-2007 02:45 AM
Hi JSegura,2) have all switch FabOS same or Lower Release 5.2.x ?
09-03-2007 12:43 AM
Hi,thanks
09-03-2007 09:02 AM
Hi JSegura,Check first the FM Server to excluded any Network Problem or conflict with the network.
09-04-2007 03:12 AM
Hi,Thanks
09-04-2007 03:46 AM
See this Topic regard Port used by FM.This is another story, to see if the Problem caused by the Firewall, deactivated them and Test is the FM work.
09-04-2007 06:55 AM
Hi,Thanks.
09-12-2007 04:43 AM
Hi,thanks
10-03-2007 09:23 AM
I have the same problem about Monitor Fabric and rx/tx history. Currenlty, I install FM 5.2.0a on Solaris server. I enable Performance monitor on Fabric Manger too. I have found that FM 5.2.0a cannot collect Performance monitor and End-to-End monitor on some switches. ( There are two SW48k ).. Do you can solve this problem case? If you solved , Could you pls guide me this case. Thank you very much.
