Anonymous
Migration from point-to-point to single fabric
Existing SAN
External Moderator
Re: Migration from point-to-point to single fabric
Hi LinuxDude,fine all this, but what is you problem ?
TechHelp24
Anonymous
TechHelp I just wasnt sure the procedure I described would allow the IBM Blades to continue to operate without fault when I reconnected the cables from the Blade Center and DS4300 to the switch.Many thanks good sir
Anonymous
BTW I'm really new to SAN technology. So this might be why I appear to ask easy questions <!graemlin::)>thanks
External Moderator
Hi LinuxDude,
TechHelp24
External Moderator
I was also to begin without experience, none gives simply asks, and none simple answer <!graemlin::)><!graemlin::)>
TechHelp24
Anonymous
It has 2 switch modules installed in the Blade Center. They both look exactly the same and have<!graemlin::)>Thanks
External Moderator
Hi, create web-tools screen from the Blade Switch and post here. It is probably that is McDATA but not sure. Again, the best way which it describe here, to Expand the SAN whit a new Switch.
TechHelp24
Anonymous
I can find out how to gain access to the management module of the Blade Center. This should provide all the info I need right?Many Thanks!
External Moderator
Hi,If you not are sure, create a screen from web browser and post here.
TechHelp24
