Occasional Contributor
Accepted Solution
Merging CISCO UCS with Brocade FC switches
Hi guys,
Is there somebody who have practical experiences with interconnect those two technologies ?
Currently there is big project against me. Task is connect CISCO UCS:
FABRIC INTER - UCS6248UP
with brocade switches:
BROCADE 6505
ATL-FS02-63:martin.karlik.ad> version
Kernel:     2.6.14.2
Fabric OS:  v8.0.1b
What to check, what to watch out for, what to configre, and how,  in order to make it to work properly ?
Regards,
Martin
External Moderator
Re: Merging CISCO UCS with Brocade FC switches
@Martin_Karlik
not sure what you mean with "Merging" ?
I assume you want to Connect / ISL UCS to Brocade, if yes:
on Brocade side, the port must be set as NPIV, and port speed should be set as fixed speed instead AN.
that all what you need.
TechHelp24
Frequent Contributor
Do you have access to a Brocade sales team?
See PM.
Yes we have few UCS-SPL-5108     - CISCO CHASSIS with USCB-B200-M4     - servers, UCS6248UP         - FABRIC INTERCONNECT,  and we want connect it to Hitachi storage via brocade switches.
@Antonio Bongiorno TechHelp24 wrote:
@Martin_Karlik
No I dont.
External Moderator
[ Edited ]
Hello @Martin_Karlik
this is very easy to config and supported.
as sayed, you need just to configure the port in Brocade 6505 as NPIV, usually is alredy set as NPIV by Default.
accord you native question no mater if you use 8 or 16Gb SFP+:
BROCADE 6505  and FOS:  v8.0.1b
you don't need other settings, excepted you have other Old switch ( 8Gb also Gen4 ) in the Fabric where you want to connect the UCS,  then is mandatory to set the  "portcfgfillword"
however since this features is no longer available in most Gen5 Platforms with FOS 8.x excepted in DCX-8510 with AP Blade, is no required to set.
have a fun.
One Thing is not clear to me,  - as suggested by another user -  why you should get in touch with Brocade Sales Team ????
that would be interesting....
TechHelp24
Hello @Antonio Bongiorno TechHelp24
Thank you very much, I will try it, plan is to run it in ~ next moth.
I also have no idea why I shoud get with Brocade Sales Team :)
