Turn on suggestions
Showing results for
09-01-2010 02:03 PM
Hi,
I have two MD 4700 switches that I need to reset the password on. I have used the site here and found the instructions for my particular software release (08.00.012 build 2).
Instructions are to login using redips or neergcm. (no problem, although strangely one switch does not respond to neergcm...)
enter pcp swoff
enter pcp nvreset
enter pcp swon
reboot
however after entering these commands, the switch does not reset. The ip configuration remains as was and the default login info does not work.
Here is my command output:
>xxxxxxx
{P} SSP>pcp swoff
OK
{P} SSP>pcp nvreset
PCP Custom Commands are already registered.
{P} SSP>pcp swon
{P} SSP>
At this point i haveexited and rebooted the switch by holding the reset button for 10 secs as well as simply pulling the power plugs.
I must be missing something elementary.
Thanks in advance,
Scott
03-16-2013 03:24 AM
Scott,
did you ever get this resolved?
i just acquired an ES-4700 and am in the same boat. I can't get into the swtich and the posted reset procedures do not work.
if you have any information, please post or contact me at "brian dot chinn at professionalconcepts dot net"
Thanks
