Turn on suggestions
Showing results for
03-07-2017 12:01 PM
I know that McDatas are EOL but I am looking for the latest version of the firmware for the Spheron 4700 to update some FC switches we have in our test area. Does anyone here have a copy? I can't find it anywhere and they are no longer supported so I have no other options.
Thanks
03-07-2017 01:25 PM
McDATA microcode is no longer available for download, latest release is 9.9.9 RN is attached.
keep in mind depend the Release installed, you need to upgrade in more step.
03-07-2017 01:37 PM
Antonio, thank you for the information. I know the code is no longer available for download. That is why I am asking if anyone has a copy. I have had to resort to buying used 4700's off of ebay to see if they have the newer firmware (newer than 9.0.0). Seems silly to go through all this work if someone has a copy.
Thanks
03-07-2017 10:13 PM
I'm very sorry but I'm not authorized to distributed FW package, however I would suggest to ask Brocade Support.
Generally, no matter if the Products is EOL, Download is only available with Active maintenance Contract.
