Turn on suggestions
Showing results for
12-26-2010 02:56 PM
Hello.
I am new to SAN and would like to teach myself by setting a little SAN environment at home. I have bought McData 4500 switch off eBay, then I bought several Finisar's GBIC modules. I tried to register a serial number of the switch with Brocade, but I am getting automated replies that it is not a valid serial number...
I am at a loss on where to get the management software!? The manuals refer to "Element Manager" or SANavigator software. Is there any place online where I could get trial editions of that software? Or buy a used copy of SANavigator, since it is no longer supported...
Thank you for your help.
Slava
12-27-2010 11:28 AM
How about using the integrated BUI? If you point your browser at the 4500's IP address, it should launch the BUI which can perform just about all functions of the switch.
Depending on the firmware installed, the BUI is referred to "EFCM Basic" or in older versions it was called "SANpilot."
12-27-2010 04:54 PM
Thank you, JayMike3.
I was able to find out the IP address of the switch, by using Wireshark, and now I am able to open a telnet session or a web page of the switch!!
The problem that I am facing now - I do not know the admin's name nor the password. I used the reset button (holding it for 10 seconds), but I am not sure, if it did reset the user name/passwords to their defaults... Is there another way to reset them? What are the defaults?
Sincerely,
Slava
12-28-2010 10:09 AM
The old 4500 Install & Service Manual is still available here:
http://mcdata.com/downloads/tpub/imanual/4500serv_ism_eos_eosn91.pdf
In there (page 2-1) you will see the default login is "Administrator" and the default password is "password".
If the password has been changed, then you should be able to go into the serial port and reset it (see info starting at page 2-30). Once you've established a connection to the serial port, login by entering the password of "level-2" (also seen on page 2-1). After logging in, if you type "help" you should see an option for "PSWD_RESET" which is what you could run to reset the passwords back to default.
But hopefully they are already at default and you won't need to reset them.
-j
