Turn on suggestions
Showing results for
02-12-2014 06:57 AM - edited 02-12-2014 07:28 AM
I have two HP MSA P2000 FC Drive arrays that are connected to a BR340 Switch. Also Connected to the Switch is a HP C7000 Chassis with an Internal Brocade FC Switch Module. From the MSA I can see all of the Blades that are in the C7000 Chassis, though I cannot see one MSA from the other. The Last System I setup without the BR340 and just used the Internal Brocade FC Switch in the c7000, I could see the remtoe MSA with no issues.
I have configured zoning based on the PWWN for the MSAs. Controller A, FC1 and Controller B, FC1 on each of the MSAs are connected to BR340 Fabric 'A' Swirch and FC2 [orts are Connected to Fabric 'B' Switch. Both Switches are configured the same.
I have Included the Switchshow and Zoneshow of the BR340 Fabric 'A' switch.
DALWW_BR340_A:admin> switchshow switchName: DALWW_BR340_A switchType:71.2 switchState: Online switchMode:Native switchRole: Principal switchDomain:1 switchId:fffc01 switchWwn:10:00:00:27:f8: D4:33:73 zoning: ON (BR340_A_Config) switchBeacon: OFF Index Port Address Media Speed State Proto ============================================== 0 0 010000 id N8 Online FC F-Port 20:70:00:c0:ff:1a:cd:40 1 1 010100 id N8 Online FC F-Port 20:70:00:c0:ff:1a:cd:f7 2 2 010200 id N8 Online FC E-Port 10:00:00:27:f8: D8:21:4a "DALWWc7000A_BC_A" 3 3 010300 id N8 Online FC E-Port 10:00:00:27:f8: D8:21:4a "DALWWc7000A_BC_A" 4 4 010400 id N8 Online FC F-Port 24:70:00:c0:ff:1a:cd:40 5 5 010500 id N8 Online FC F-Port 24:70:00:c0:ff:1a:cd:f7 6 6 010600 id N8 Online FC E-Port 10:00:00:27:f8: D8:2c:8a "swd77" 7 7 010700 id N8 Online FC E-Port 10:00:00:27:f8: D8:2c:8a "swd77" 8 8 010800 id N8 Online FC E-Port 10:00:00:27:f8: D8:21:4a "DALWWc7000A_BC_A" (downstream) 9 9 010900 id N8 Online FC E-Port 10:00:00:27:f8: D8:21:4a "DALWWc7000A_BC_A" 10 10 010a00 id N8 No_Light FC 11 11 010b00 id N8 No_Light FC 12 12 010c00 id N8 Online FC E-Port 10:00:00:27:f8: D8:2c:8a "swd77" 13 13 010d00 id N8 Online FC E-Port 10:00:00:27:f8: D8:2c:8a "swd77" (downstream) 14 14 010e00 id N8 No_Light FC 15 15 010f00 id N8 No_Light FC 16 16 011000 -- N8 No_Module FC (No POD License) Disabled 17 17 011100 -- N8 No_Module FC (No POD License) Disabled 18 18 011200 -- N8 No_Module FC (No POD License) Disabled 19 19 011300 -- N8 No_Module FC (No POD License) Disabled 20 20 011400 -- N8 No_Module FC (No POD License) Disabled 21 21 011500 -- N8 No_Module FC (No POD License) Disabled 22 22 011600 -- N8 No_Module FC (No POD License) Disabled 23 23 011700 -- N8 No_Module FC (No POD License) Disabled DALWW_BR340_A:admin> zoneshow Defined configuration: cfg:BR340_A_Config DALPDC1B1_Zone; DALPDC1B2_Zone; DALPDC1B3_Zone; DALPDMSA3K_DALPDMSB3K zone: DALPDC1B1_Zone DALPDC1B1; DALPDMSA3K_P_FC1; DALPDMSA3K_S_FC1; DALPDMSB3K_P_FC1; DALPDMSB3K_S_FC1 zone: DALPDC1B2_Zone DALPDC1B2; DALPDMSA3K_P_FC1; DALPDMSA3K_S_FC1; DALPDMSB3K_P_FC1; DALPDMSB3K_S_FC1 zone: DALPDC1B3_Zone DALPDC1B3; DALPDMSA3K_P_FC1; DALPDMSA3K_S_FC1; DALPDMSB3K_P_FC1; DALPDMSB3K_S_FC1 zone: DALPDMSA3K_DALPDMSB3K DALPDMSA3K_P_FC1; DALPDMSA3K_S_FC1; DALPDMSB3K_P_FC1; DALPDMSB3K_S_FC1 alias: DALPDC1B1 50:01:43:80:26:ed:32:18 alias: DALPDC1B2 50:01:43:80:26:ed:45:38 alias: DALPDC1B3 50:01:43:80:26:ed:35:7c alias: DALPDMSA3K_P_FC1 20:70:00:c0:ff:1a:cd:40 alias: DALPDMSA3K_S_FC1 24:70:00:c0:ff:1a:cd:40 alias: DALPDMSB3K_P_FC1 20:70:00:c0:ff:1a:cd:f7 alias: DALPDMSB3K_S_FC1 24:70:00:c0:ff:1a:cd:f7 Effective configuration: cfg:BR340_A_Config zone: DALPDC1B1_Zone 50:01:43:80:26:ed:32:18 20:70:00:c0:ff:1a:cd:40 24:70:00:c0:ff:1a:cd:40 20:70:00:c0:ff:1a:cd:f7 24:70:00:c0:ff:1a:cd:f7 zone: DALPDC1B2_Zone 50:01:43:80:26:ed:45:38 20:70:00:c0:ff:1a:cd:40 24:70:00:c0:ff:1a:cd:40 20:70:00:c0:ff:1a:cd:f7 24:70:00:c0:ff:1a:cd:f7 zone: DALPDC1B3_Zone 50:01:43:80:26:ed:35:7c 20:70:00:c0:ff:1a:cd:40 24:70:00:c0:ff:1a:cd:40 20:70:00:c0:ff:1a:cd:f7 24:70:00:c0:ff:1a:cd:f7 zone: DALPDMSA3K_DALPDMSB3K 20:70:00:c0:ff:1a:cd:40 24:70:00:c0:ff:1a:cd:40 20:70:00:c0:ff:1a:cd:f7 24:70:00:c0:ff:1a:cd:f7
